08-20-2014, 12:48 AM | #1 |
Rep 76
Wheel spacer choices
Considering adding spacers to my E86. By my measurement, it looks like 15mm front and 15-20mm rear should work. Is this pretty standard?
08-20-2014, 01:14 AM | #2 |
Rep 129
Drives: M4 F83 comp YMB X3M Comp
I had 12mm front & 15mm rears on my e86. No problems at all,this is with 18"csl reps.
08-20-2014, 11:22 AM | #3 |
I plead the 5th.
523
Rep 1,519
Just to clarify, these are going on OEM wheels? This is what I'd assume by reading your post but kermit's reply made me think it may not be the case, haha.
-Matt
08-20-2014, 11:40 AM | #4 |
Rep 25,989
The size of spacer needed will depend on quite a few variables (ride height, wheel specs, tire size, alignment specs, etc). There are consensus spacer sizes on the forum, but in order to get it just right for YOUR car.. I'd suggest:
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
08-20-2014, 04:07 PM | #5 |
Rep 76
I did measure as VRM wheels suggested. It looks like I can use 15mm on the from and maybe go to 20mm on the rear as the rears don't have the same turn angle load issues. I was happy to find that the gap is equal side to side.
This was definitely not the case on the 944 that I raced for 5 years. After having the rear suspension in and out of that car several times, I determined that the 10mm variation in the rears was due to a difference in the flare of each rear fender. I was told by several knowledgeable Porsche builders that this was a not uncommon production variance. Glad to see that the BMW is square. |
10-12-2014, 10:24 PM | #6 |
Rep 76
I ended up going with 12mm front and rear. I am running BFG Comp T/A 2s all around on stock alloys. The clearance is perfect but if I had lowered the car, I would probably have limited myself to 10mm spacers, particularly on the front.
01-29-2015, 11:12 PM | #7 |
Rep 69
Do you have pictures of your setup? I am trying to do the same.
Do it yourself Illustrative site.
http://diyrabbit.com/ |
01-30-2015, 09:59 AM | #8 | |
Rep 758
Top Down 365
01-30-2015, 10:55 AM | #9 |
Rep 747
There's also this website that may help you calculate what your offsets will come out to. Not specifically designed for spacers, but helped me out a lot.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator |
