      04-27-2012, 12:45 PM   #1
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Recaro Profi XL
Has anyone successfully installed these? If not, I'll go through the measuring process. I'm curious to see if they fit without rubbing.
      04-27-2012, 01:37 PM   #2
dorifto88
Drives: 88 Nissan Pathfinder
i have a set of regular profis, took a lot of effort lol but they are in. i have a recaro side mount and slider if you want them for cheap.
(i ended up using vac floor and side mounts, no slider)
      04-27-2012, 01:43 PM   #3
dorifto88
while i am remembering the install, here are some bits of info...
-if you do not use the oem receptacle and plug it in, you will not get auto up down windows
-as much as possible, mount the seat as CLOSE to the center section of the car (towards the transmission tunnel, so to speak)
-using a slider (for me) was almost useless cause i have no back seat, but you can still buy mine !
-i recommend buying these:
http://store.vacmotorsports.com/vac-...px?Thread=True
to use to mount your stock seat belt receptaclce (if you use it) and also the bottom seat belt bolt thing (if you know what i mean)
      04-27-2012, 01:43 PM   #4
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
aftermarket seat fitment issues usually happen at shoulder bolsters, measure that carefully
      04-27-2012, 02:24 PM   #5
sabbanick
Drives: 08 SBM M coupe
F360'c has them installed in his car...I know he said its tight with the regards to the B pillar interior trim. I would give him a PM.
      04-27-2012, 04:06 PM   #6
pokeybritches
2006 BMW Z4M  [8.50]
Thanks for all the replies! I'll PM F360. According to Recaro's website, the width is the same for both the standard model and XL. The install tips were especially helpful.
      04-27-2012, 06:40 PM   #7
ajw45
Drives: Z4M Coupe
Please let me know what you find because I'm looking at installing the XLs as well. FYI, at the shoulder they are supposed to be the same width as the non-xl but they are wider than the Pole Positions (580 vs 560mm). I measured for the width assuming the same center as my stock seats and it is close. It definitely will depend on the seat height and where the shoulder bolsters are in relation to the door panel....
      04-28-2012, 09:05 AM   #8
pokeybritches
2006 BMW Z4M  [8.50]
It will be a while before I get around to the seats. I still have headers and a set of mufflers to buy for my 3.0i before I get around to putting in the seats. I'm considering the Sportster CS as well, since this car will be primarily street-driven. My stock seats have 115k miles on them and the lateral support of high school gym bleachers.
      04-29-2012, 12:24 AM   #9
z3papa
Drives: 11 E92 M3 ZCP, 07 335i
I've got the Profi XL in my Z3. It requires a fair amount of work and slight seat tilt using washers on the outside rail to get the shoulder wings to fit without denting the door card. Great seat by the way -- much nicer than the Pole Position which I have on the passenger side. Both have been recovered in leather.
Sold 2011.5 E92 M3 ZCP.
      04-30-2012, 11:26 AM   #10
pokeybritches
2006 BMW Z4M  [8.50]
Did your vendor cover them in leather, or did you get them done at an independent shop? I'm glad to hear they are better than the Pole Positions. I sat in a Pole Position at Bimmerfest, and I was definitely too tall/large.
      04-30-2012, 11:36 AM   #11
F360C
Drives: E86 S54
The Profi XL will fit in our cars. I have a set and didn't have to modify the seat at all to make it fit. I am running the Recaro side mounts with the VAC floor mounts. The only modifcation I had to perform was to enlarge one of the mounting holes on the side mounts which took all of 30seconds. I am also running the stock 3pt seat belt.
07 Z4 M Coupe AW/IR
      05-01-2012, 09:01 PM   #12
ajw45
Drives: Z4M Coupe
That's awesome! Pics?
      05-03-2012, 07:29 AM   #13
z3papa
I had them recovered at a local upholstery shop as the side bolsters were getting a little thin. I haven't taken pics yet but will endeavor to get that done and posted here as some on Bimmerforums have asked for the same. Ironically, most of the pics of my car are by competitors.
      05-03-2012, 08:15 AM   #14
F360C
Drives: E86 S54
If you don't mind me asking approx how much did it cost to have your seats recovered? I am thinking of getting mine redone in leather/suade too.
07 Z4 M Coupe AW/IR
      05-03-2012, 06:37 PM   #15
OG_M3
Drives: ae86; z4mc
2011 BMW M3  [0.00]
2007 BMW Z4MC  [0.00]
1985 AE86  [0.00]
airbag light? also, do you have sliders as well or is your seat in a fixed position?
      05-03-2012, 07:40 PM   #16
F360C
Drives: E86 S54
Light is currently on but I was able to turn it off with a piece of electrical tape. I have been in contact with people that know the airbag systems better than anybody and currently the only solution we have come to is to get an OC3 mat. The SRS system in the Z4 is a very unique system and difficult to trick.
I have sliders but don't run them. I want the seat mounted as low as possible and since nobody drives the but me and my brother from time to time having a fixed mount is perfect. My butt cheeks are literally less and an inch off the deck.
07 Z4 M Coupe AW/IR
      05-11-2012, 09:14 PM   #17
3002 tii
3002 tii's Avatar
2286
Isn't it possible to transplant the oem sensor into the Recaros?
Follow for latest mods
      05-11-2012, 09:59 PM   #18
dorifto88
i was thinking about doing this. anything is possible, but i didnt want to have to pay a shop to take the seats apart and then put them back together.
