01-27-2010, 03:35 AM | #23 |
Rep 1,269
I had a set of 19". The weight was about 27~28lbs front and 29~30lbs back. I hated them every mile I had them. Killed the acceleration and steering response, and made the car feel heavy and no longer agile.
2019 Porsche 911 4 GTS
2016 BMW M3 2008 BMW Z4M coupe |
01-27-2010, 03:28 PM | #24 | |
Rep 2,120
Drives: ///M Roadster + E92 335i 6MT
Imola Red Roadster |
02-09-2010, 05:12 PM | #25 |
Rep 2,120
Just bumping this again,
Do we need to run spacers on these or are they good to go out of the box?
02-09-2010, 07:10 PM | #27 |
Rep 2,120
Stunning,
BTW do you run any spacers with yours?
02-09-2010, 08:07 PM | #28 |
Rep 1,660
On my ZCP I don't run spacers, but to run stock front track width you would need a 5mm spacer. Without spacers, the fronts look a little sunken.
Current: '13 E92 M3 Euro Delivery Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3 |
02-10-2010, 08:04 AM | #29 |
Rep 1,373
Yu can run them just fine with out spacers but the front ZCP wheel is not the same offset as the OEM Z4M front wheel so it is a little sunken in. I think a 10mm spacer makes it look good but I went with a 15mm based on the recommendations from Rogue Engineering. I think the 15mm makes it look perfect but you couldn't run the 15mm with a stock alignment. It needs extra front camber so the wheel doesn't rub which is not a problem for me since I run -2.5ish. As far as the rear goes they look fine with out spacers but a 5mm spacer would make it look perfect. I was going to buy a 5mm spacer for the rear but I ended up picking up a set of 285 rear tires for stupid cheap to replace my worn 275s and I think the 285 will fill the arch just perfect with out the spacer
07 Z4 M Coupe AW/IR |
02-10-2010, 08:52 AM | #30 | ||
Rep 2,120
Have to decide if I should get these or a new exhaust, then begs the question on what exhaust to get! I don't want too loud so from research I'm thinking Remus, or SS powerloop, I just really have a thing for the CSL's
02-10-2010, 10:23 AM | #31 |
Rep 5,328
starsscream ive got genuine CSLs on mine with the 8.5 up front instead of the 8 and they sit pretty much flush like the rears with no spacers at all, they look perfect, ill get some pics of the front, i personally wouldnt run spacers on any of my cars, ive got a pet hate for them!! like i originally said try and source csls if you can.
02-11-2010, 01:09 AM | #33 |
Rep 2,128
Yep, the CSLs work without them (I thought your spacer question was about reps), but you can't get them here new. Cruise the E46 M3 forums and you'll likely find some for sale used. I snagged mine via Ebay.uk, but it was about a grand more expensive than ZCPs.
02-13-2010, 08:31 AM | #34 | |
Rep 1,373
http://www.m3forum.net/m3forum/showthread.php?t=307100
02-13-2010, 03:41 PM | #35 | |
Rep 393
Drives: E86 Z4 M Coupe
Garage List MK4 VW GTI 1.8 Turbo [0.00]
MK1 VW Rabbit GTI ( ... [0.00] E90 335i sedan [0.00] E86 Z4 M Coupe [7.50] E36 325is (Track Car) [0.00] |
03-02-2010, 08:08 PM | #36 |
Rep 2,120
Ok got my CSL's today from Evan at Tischer,
God they are beautiful, there is no new, Like brand new lol now guys who have these wheels, I'll be running 245/35/19's up front, I see there have been a few sizes of spacers thrown up, Are they really needed? and those who have them can anyone give me any links to buy them? and what about bolts? stock ones fit or you need new ones?
03-02-2010, 08:13 PM | #37 | |
Rep 1,373
