05-17-2017, 06:00 PM | #1 |
Rep 12,565
Style 5's on Coupe?
Anyone done before? Curious how it'd look...
05-17-2017, 07:23 PM | #2 |
Rep 758
I tried mounting the set I had on my 3.0si roadster and they interfered with the front calipers. It wasn't a diameter issue, it was the ends of the bolts that hold the wheel center in that interfered with the outside of the caliper body. Might have been able to fix it with spacers, but they were 17 x 8 ET20 from an E39 and the spacers would have added even more offset.
I think they'd look pretty good if you got them to fit, but then I've been a long time Style 5 fan.
Top Down 365
05-17-2017, 07:49 PM | #3 | |
Rep 12,565
05-17-2017, 10:13 PM | #4 |
///M Enthusiast
43
Rep 110
Not style 5's, but similar:
https://goo.gl/80QTN2 Or just google "z4m stance" if you have issues with that link.
///M Coupe - Volk TE37's 19x10.5R +22 19x8.5F +30 | KW V3 w/ Clubsport rear springs | RPi exhaust | Autosolutions SSK | RE transmission mounts | RE RSM's | Vibra-Technics engine mounts | RPi scoop | RPi skid plates | Tekarbon spoiler | Apex wheel studs | Blox burnt titanium lug nuts | UUC Front 27mm Swaybarbarian | Status Gruppe adjustable front links | EAS Blacked out kidneys | Full Beisan Vanos Refresh
05-18-2017, 12:50 AM | #5 | |||
E86 M Coupe
265
Rep 403
Dc_wright means that the bolts/nuts on the backside of the two piece style 5 face have no clearence to mount flush to the wheel hubs due to the calipers interefering with the front/top of the front caliper, so he mean you will need a spacer to clear the caliper face/top behind the spokes. So the wheel can spin freely without rub/grinding from the nuts/bolts to the caliper and while maintaing full contact to the wheel hubs. You are correct about the hubcentric ring being recommened. The style 5's (17x8 et 20) are quite light for a factory bmw wheel weighting in at 21lbs just fyi. Im also a fan of the rc090s (17s) but the rc092(18" style 5s are ) Quote:
05-19-2017, 09:19 AM | #6 | |
Rep 758
Yes, I'm aware of the E39 hub size difference as I had the hub centric rings to fit the Style 5s on my E36.
Top Down 365
05-19-2017, 12:31 PM | #7 | |
Rep 12,565
