      05-07-2014, 01:33 AM   #1
donoman
Rookie
33
Drives: 03 Z4 2.5i 5MT
Cruise control not working ... need help debugging
Hello All,
Like the title says, the cruise control in my car doesn't respond to any inputs. I cannot arm the system by using the stalk. I have checked the fuse already (#21) and it's OK. I have also tried to start the car without pressing the clutch in, so I'm assuming my clutch switch is working. My brake lights work fine, so I'm assuming the brake switch is also working.
What am I missing here? Are there independent switches on clutch,brake for cruise control system?
Thank you,
donoman
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      06-19-2014, 10:07 PM   #2
jmilt13
jmilt13's Avatar
19
Drives: 3.0si Coupe
Bump, any ideas how to trouble shoot this?
      06-19-2014, 11:45 PM   #3
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Yes. A BMW scanner is required to read the fault codes. They run about 50 bucks on EBay.
My guess is a faulty module or relay. But diagnosing w/o a scanner, ouch.
      06-20-2014, 12:11 AM   #4
donoman
Rookie
33
I have INPA, you think this will be sufficient?
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      06-20-2014, 12:14 AM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
Maybe, but I think this calls for DIS.
If you have the typical eBay rig, you should have it.
      06-28-2014, 02:02 AM   #6
jmilt13
jmilt13's Avatar
19
Drives: 3.0si Coupe
Any luck Donoman?
      06-28-2014, 02:22 AM   #7
donoman
Rookie
33
I checked for errors, I have 2F67 which is a clutch switch signal. Going to see what's up with that, as it could very well be the reason Cruise isn't working.
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      07-06-2014, 09:11 PM   #8
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
sounds like the clutch switch is bad, so it either (a) thinks the clutch is on all the time, or (b) can't tell when it assumes the clutch is on, so it just assumes it might be on.
I had a similar issue on my Audi where my brake switch was stuck on, so it wouldn't let me initiate cruise control.
