07-19-2012, 10:08 AM | #1 |
Rep 1,224
Thinking of removing my TPMS wheel sensors.
Thinking of removing my TPMS wheel sensors. Coming up on the 5 year mark for the car and looks like I’ll need tires before the end of the year. My understanding from the various threads on sensor life is that they typically last 5-7 years. Based on my driving style I anticipate my current sensors will fail long before I’m ready to do tires again.
I see my options as: 1. Proactively replace all 4 sensors now with the upcoming tire change to avoid the expense of unmounting / remounting the tires to install the new sensors. 2. Leave the current ones in and apply black tape over the warning light when they fail. I really don't see this as an option. 3. Remove the sensors when I do the tire change and place them in a small pressured container and carry in the car. I check my tire pressure regularly and with non-runflats, the removal of the sensors are not critical. Thoughts? Options I haven’t considered? Is there a way to disable the warning light bulb/wiring? Thanks
07-19-2012, 10:18 AM | #2 |
Rep 11,667
I just removed mine & am using option 2 at this point.
I decided that #3 was more effort than it was worth. I'm not aware of anyone that has done Option 3 and made it work. I think there will be an issue with shielding of signal and distance sensor>trunk. To have any hope of making it work, I think you would need 4 separate canisters and mount local to the sensors at that wheel well.
07-19-2012, 10:33 AM | #3 |
Rep 146
Option 4. - buy a 2006 with no TPMS sensors (indirect TPMS).
2006 ///M Coupe TiAg / IR | BBS RS-GT / BBS RK | Ground Control | Supersprint X-pipe + Race | BMW Motorsport 3.91 final drive
2009 328i |
07-19-2012, 10:39 AM | #4 | |
Rep 1,001
07-19-2012, 11:08 AM | #5 |
Rep 1,224
For those who are using Option 2, any residual glow around the tape edges at night?
Where are the TPMS receivers located on our cars? Are they accessible?
07-19-2012, 11:49 AM | #6 |
Rep 12,565
Can't you pull out the fuse so that you don't get a dash warning? Then you could run without them and not have to worry about the dash light neither.
07-19-2012, 01:16 PM | #7 |
Rep 1,224
It's been a while but I thought someone tried that and had some type of related problem, can't really remember what the issue was. Has anyone unplugged or removed the warning light?
07-19-2012, 04:19 PM | #8 |
DHS
203
Rep 4,010
Drives: 2023 M4, 2020 Land Rover
Do option two and have them coded off at EAS, done and done.
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
07-19-2012, 05:31 PM | #9 |
Rep 2,138
Drives: Me
Pictures:
1 |
07-20-2012, 05:31 PM | #10 |
Rep 1,224
HK and Ship, thanks for the info.
I contacted EAS and as HK mentioned they can recode to remove the warning light. It will be a few days until I can get to my car to try this: Has anyone unplugged the receivers? Any lights?
07-20-2012, 05:50 PM | #11 |
Rep 815
Boy, am I feeling ghetto after seeing Shipkiller's set up. I bought a cheap set of TPMS on Ebay and installed them in a new set of wheels/tires about a year ago. Sure enough, one (or more) of the sensors failed to work and I got the yellow gauge light.
I couldn't bring myself to dismount tires just to hunt for and replace a bad sensor. So I took a little stick-on label from the stationary pile, colored it in with a black indelible marker, cut it down to about 1 cm and stuck it over the gauge light. Utterly invisible in daylight, faint exclamation point visible at night. Would I prefer to have a functioning TPMS system? Sure. But now I just carry a tire gauge and check periodically - the same as I have with every other car I've owned for the last 35 years. No big deal. |
07-20-2012, 06:46 PM | #12 |
Rep 2,138
Drives: Me
My buddy had some failing TPMS sensors on his C5 track wheels. We took the wheels over to the Military Auto Hobby shop (a DIY shop). Put each wheel on the wheel machine, broke the bead at the sensor location and deformed the tire just enough to pull the sensor out and replace with standard stem. Re-inflated and reset the bead. Done. 10min per wheel. No re-balancing required since the tire did not move around the wheel.
07-20-2012, 06:58 PM | #13 |
Rep 1,543
So I guess the conclusion is to tape it over or get coded?
No unplugging of any sort to fix it? I hate my light since my wheels is not tpms compatible and I like my wheels.. |
