      03-08-2019, 08:47 PM   #1
WeekendWarriorz
WeekendWarriorz's Avatar
670
Drives: 2006 Z4M
E46 M3 vs Z4m oil pan difference
Does anyone know if there's a difference between the e46 M3 and Z4m oil pan? Visually, they look exactly the same, and I mean exactly.
The E46 uses the part number: 11137838130 while the Z3M and Z4M share the same part number of: 11137838132
I'm not sure if there's any differences or if the last digit is changed just because of the different chassis but anyone with any information or who has any experience would be greatly appreciated! Thanks!
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold
2006 Z4 M Roadster Black/Black-Sold
2021 M2 Competition DCT Hockenheim Silver
      03-08-2019, 09:11 PM   #2
mattfwalters
mattfwalters's Avatar
Drives: 06 Z4MC (Sepang/Sepang/insane)
They are exactly the same. The Z4M uses the same front crossmember as the E46 M3, but a different dipstick / DME, so I suspect those two part numbers come with with either different dipsticks / seals or a different oil level sensor. But the pan casting itself is identical.
      03-08-2019, 09:14 PM   #3
WeekendWarriorz
670
Drives: 2006 Z4M
Awesome this is exactly what I'm looking for. Thank you! How is the Z4m dip stick different from the e46 if you know?
      03-17-2019, 08:23 PM   #4
mattfwalters
It's got something to do with the airbox, IIRC. I can't remember exactly. I know that the M3 has a different intake elbow and the vacuum lines are a bit different around the elbow, but I think the Z4M and M3 share the airbox plenum itself. So I might even be wrong about the dipstick being different.
      03-17-2019, 09:01 PM   #5
WeekendWarriorz
670
Drives: 2006 Z4M
Ah gotcha, yeah I know the Elbow is slightly different and the Z4m has a vacuum line off it. If the molding is the same I'm going to be going with an M3 pan since the threads on mine got stripped out from the dealer over tightening
