      11-27-2018, 07:00 PM   #1
JimBob0047
Drives: 2006 Z4MR
Car has 56k miles on it. I've only owned it for a month or so. Your thoughts would be greatly appreciated!
      11-27-2018, 07:22 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
0 lead is a good thing!
May the road rise up to meet you, and your lead always be low.
      11-28-2018, 12:41 AM   #3
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Not necessarily. If you just installed fresh bearings, then yes, 0 lead is a great thing! But without that information, 0 lead with elevated copper could very well mean that the lead layer had worn away and probably already into copper. With a high iron reading on top of that, it may even be into steel...so I would be worried about bearings. These rod bearings are made of steel/copper/lead. Steel is an alloy, but most of it is iron. Just my opinion.
      11-28-2018, 01:21 AM   #4
StickMon
StickMon's Avatar
Drives: 2006 MR
At 56k miles you would have had to flog her pretty hard to have that happen.
But I agree, insufficient information.
      11-28-2018, 07:14 AM   #5
JimBob0047
Drives: 2006 Z4MR
That's what I was thinking. Not sure what the previous owner did. Not sure how long the oil was in the car before I bought the car and changed it. The report states that it may have been a lower viscosity oil. We will see what another analysis says after 3k. Now using Motul 10w60 oil.
      11-28-2018, 09:31 AM   #6
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Mine was reasonably driven and maintained - you can see the condition of its bearings at roughly ~55K miles => https://www.zpost.com/forums/showthread.php?t=1461006
      12-18-2018, 02:51 PM   #7
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
I still haven't done my bearings, yet, but I haven't driven the car in quite awhile, either. Been busy with other projects. Guess bearings will now be my spring project. I'd be worried with elevated copper.
      12-20-2018, 03:59 PM   #8
RossBMWZseries
Because of you, I have an appointment at the shop on 01/03/19 to have my rod bearings replaced, and I thank you!
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
      03-06-2019, 07:07 PM   #9
JimBob0047
Drives: 2006 Z4MR
Changed at 58k. Black stone analysis was on the money.
      03-06-2019, 10:02 PM   #10
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Originally Posted by JimBob0047 View Post
Changed at 58k. I wouldn't trust blackstone analysis.
Why not? 0 lead with high copper meant you had already gone through your lead layer and into copper, which is exactly what your bearings are showing
