      01-03-2017, 01:04 PM   #23
GuidoK
GuidoK's Avatar
10855
Drives: Z4 3.0i ESS TS2+
but it's the adjustments for the other gears with a spring return to 3-4 home position that really makes the CAE so nice.
I think for this function to work best is to have stiffer engine and gearbox mounts (like you already have).
The normal shift joint (ball joint) sits in a subbeam (shifting arm) connected between gearbox and chassis. That means that the oem shifter moves accordingly to engine/gearbox movement to keep the shift rod inline with the proper gear selections. This is also one of the reasons the OEM shift lever has so much slob. The rear bushing of the shift arm is a very soft bushing, probably for comfort/NVH. The movement in that bushing+movement/play in the ball joint is basically the total slob of the oem shift system. (upgrading that bushing is a simple/cheap way to reduce that slob partly)
By relating the shifter position to the chassis and not to the engine/gearbox (like the cae shifter), its best to minimize the gearbox movement.
I dont have irl experience with this problem but I could imagine when under high G's the engine could move so much with OEM mounts that it could get out of line for 3/4 shifting (so that the gearbox isnt aligned anymore with the 3/4 preset).
The oem mounts are very soft, especially the gearbox oem mounts (you can squeeze them with your fingers).
      01-03-2017, 02:09 PM   #24
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
What you mention makes sense & Something that I definitely thought about.
Reading on the CAE site they claim
" • Problem-free shifting of gears under stress or in curves. "
which i thought to be a strange statement to make.
....when the say stress, maybe they're referring to the driver not the car.
      01-03-2017, 02:38 PM   #25
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Your ID should be theZ4einstein
Instagram: ariusen26
Youtube: Track vids
inTgr8r2431.50
      01-03-2017, 02:58 PM   #26
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
LOL.... thanks, but not even close.
      01-04-2017, 01:30 AM   #27
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
Yes, BMW has a spring for reverse, but its not an actual lockout stop.
I could live without the lockout stop, but it's the adjustments for the other gears with a spring return to 3-4 home position that really makes the CAE so nice.
Unlike BMW gear boxes? Nontheless, nice shifter!
inTgr8r2431.50
      01-04-2017, 10:24 AM   #28
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks..... Yes, I should have clarified, there are two spring returns in the tranny.
But they are sloppy and vague.
The CAE spring makes it a more precise 'home' position.
If you look at the pic from the underside you can see it's a single spring and how it is double anchored with a centering pin.
You get immediate feedback leaving or returning to 'home'
      02-04-2017, 12:12 AM   #29
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Finally got some time to read through your install notes. And yes you are spot on, I'll be adding this to my list of "must do"
Very well executed Ian, top job.
inTgr8r2431.50
      02-04-2017, 01:09 AM   #30
FD3S
Drives: BMW Z4M
Great job, very professional installation and post!
inTgr8r2431.50
      05-15-2017, 07:07 PM   #31
ANILE8
ANILE8's Avatar
No_Country
180
Drives: Z4 M Coupé - Carbon Black
If using the OE shift rod can you install everything from above or do you still have to drop the exhaust system and driveshaft?
Why did you have to use the AKG DTM Selector Rod?
Do you have to mount the CAE shifter backwards? It looks like crfine88 installed his in the normal forward direction.
Anyone know how the CAE compares to the AKG Stage II shifter?
Can you say if the 1 - 2 shift is noticeably faster?
Defiantly a mod I want to do depending of the difficulty scale and time required to install.
Have only two forum member done the install here?
      05-16-2017, 01:47 AM   #32
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
I installed something similar, but without the reverse lock out. Its one of the 2 mods i love the most in my car. You cannot use the OEM selector rod, you need a DSSR, or this won't work. and yes you have to drop the shaft and exhaust to fit it. i can only speak for myself, but its a completely different world to the oem shifter and shift behaviour. I am sure Ian will say similar.
Hey man, your an Aussie, you have PM incoming.
Powered by
      05-20-2017, 06:43 PM   #33
ANILE8
ANILE8's Avatar
No_Country
180
Hi inTgr8r, just waiting to pull the trigger and order this CAE shifter as I have found one at a amazing price but wanted to ask if you have any pics of the shift boot installed? This is the only thing that is holding me back.
Didn't want to leave it off as mine is still a street car and I like to keep the look factory clean. CAE make about 15 different shifters for VW and trim panels for Porsche owners but only one shifter and no trim panels BMW? Come on CAE, obviously we are not your target market.
      05-20-2017, 08:11 PM   #34
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I haven't finished the boot off yet.
Still looks like this.
I plan to trim it with an inverted boot with the CAE exposed.
      09-06-2018, 03:11 AM   #35
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
How did you end up trimming this?
      09-06-2018, 08:10 AM   #36
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I didn't, but the plan was to buy a used boot and cut it so that it fit around the base.
      09-06-2018, 11:28 PM   #37
StickMon
StickMon's Avatar
Drives: 2006 MR
That thing is so damn cool looking that you have to make the inside of the boot very low around the base.
I haven't been to a fabric store in a long time, but maybe they would have a 6"x8" piece of nice leather cheap and easy?
      09-27-2018, 12:31 PM   #38
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
Looks like there is a model specific option for our cars now!
http://www.hardmotorsport.com/cae-ultra-shifter-bmw-z4/
Now to find an extra $1,200 and a good enough reason to justify the purchase to the misses....
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
inTgr8r2431.50
Vanne1620.50
      11-08-2018, 07:06 AM   #39
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
Several less expensive products are now available:
https://www.psdesignsglobal.com/brands/rtd-shifters/
https://www.irp.lt/
https://store.vacmotorsports.com/sam...ons-p2997.aspx
      11-08-2018, 11:20 AM   #40
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
These units are certainly nice and the stronger centering-spring is helpful. But considering the cost of even one of the alternatives, I honestly don't see the ROI compared to a proven Bimmerworld Solid Mount setup. No interior mods needed either.
https://www.bimmerworld.com/SpecE46/...waAqEDEALw_wcB
      11-10-2018, 08:48 PM   #41
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Azeka1, those are solid shifters, not ultra shifters. That's the difference. The ultra shifters have the pivot point up much higher so much less throw is required.
      12-28-2018, 10:07 PM   #42
ANILE8
ANILE8's Avatar
No_Country
180
Why is it a persistent problem with DSSR fitment for our vehicles?
From what I have seen both the UUC and AKG DSSR's need modification (bending) to fit. If this was not mentioned at the time of purchase, I would have returned them.
What is strange is that CAE are now offering a DSSR for our vehicles but from what I can see from their website on the Z4 shifter page they are recommending their XXL DSSR version but they look to be straight design and without any bend I do not know how they will clear our guibo.
What do you guys think about this?
https://cae-racing.de/CAE-Ultra-Shifter_2577
https://cae-racing.de/Shift-Rod-XXL
      01-02-2019, 11:44 AM   #43
Michael9218
595
My thoughts on the adjustable DSSR is that it looks like a sub optimal solution. I think a two part rod with a clamp is not going to be precise and is a problem waiting to happen.
As for clearance over the Guibo, good question...how does this one clear it?
      01-03-2019, 10:33 PM   #44
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
I got my DSSR done completely custom. One solid piece. Might have a pic if it somewhere, agreed with Mick, that looks like a problem waiting to happen.
