      06-29-2014, 04:41 PM   #1
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
S54 noise?
I've wondered this before and basic searching shows people saying that the S54 is simply a noisy engine but I decided to take a video to see what you guys think. Is this normal noise at idle? It is most noticeable from beside the car near the front wheels. When I open the hood all the noise kind of just blends together but with the hood closed and from the side there is this rhythmic ticking sound. I also occasionally hear a rhythmic ticking around 2500-3000RPM sometimes.
      06-29-2014, 06:23 PM   #2
donoman
Rookie
33
Drives: 03 Z4 2.5i 5MT
It's definitely a noisy motor. From your video sounds normal. If ticking is excessive you may be due for a valve check.
I also felt like the damn thing was about to blow up first few times I heard it since my other car has the 2.5l M54 motor. Go to a BMW meet and listen to the other S54's if you want to be sure.
      06-29-2014, 06:56 PM   #3
mtrhed
mtrhed's Avatar
13
Drives: 06 AW Z4MR/w211 e63 AMG/325XiT
Sounds normal. Added "ticking" in the RPM range you mentioned is most likely the VANOS splined shafts rattling. Once again normal and should "fade" as the revs climb.
06 Alpinweiss Z4M R
Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake
      06-29-2014, 07:19 PM   #4
bjbstewart
bjbstewart's Avatar
Drives: 2007 BMW Z4MC
I've had mine for almost a year now - ticking bugs the heck out of me, but I've come to accept it...
I like what Donoman said - go hear some others for peace of mind...
[SIGPIC][/SIGPIC]
      06-29-2014, 11:37 PM   #5
ried
ried's Avatar
Drives: F31, F80
100% normal.
      06-30-2014, 01:33 AM   #6
Beedub
spounds like mine.... and mine only has 11k miles. lol!!
normal!!
      06-30-2014, 06:41 AM   #7
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
I love how noisy it is. Sounds aggressive and means business haha
instagram: @ dubsesd
      06-30-2014, 06:43 AM   #8
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
sounds like mine and mine has 200K kilometers on it
Powered by
      06-30-2014, 11:24 AM   #9
kdphan
Drives: everything is gone!
sounds normal
my e92 M3 had the same ticking from what i remember
      06-30-2014, 01:05 PM   #10
gas-can
Drives: 2006 3.0i Roadster
Doesn't the S54 have solid lifters instead of hydraulics? That sounds just like a little bit of lifter noise.
Solid lifters are almost always going to be louder than hydraulics. Hydraulics automagically reach zero valve lash when they are filled with oil. Benefit with solids though is no pump up or bleed down - so better performance at high rpms.
-gc
      07-01-2014, 02:51 PM   #11
Swashplate
Swashplate's Avatar
Drives: in Anger.
This.
Just like listen to the motor on the E39 M5. Mmmmmmmm
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs
1217/1815
!!! BOILER UP !!!
      07-01-2014, 03:06 PM   #12
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Is this a warm or cold engine recorded? You may want to check the torque on the plugs; I had one loose, not finger loose, but enough to create an audible. What is the history on the valve adjustments? I also found using the craftsman feeler gauges, as opposed to the BMW tech gauges, the engine was quieter, perhaps more precision involved. It's also good to have the ticking on the exhaust side, those valves must touch the head.
      07-01-2014, 10:10 PM   #13
intoflatlines
Warm engine, I will torque the plugs. Valve adjustment was done last summer, around 4K miles ago.
      07-03-2014, 11:26 AM   #14
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
Mine sound just like that and the valves got adjusted like 700 miles ago. And it have 31K miles on the odometer.
