      12-02-2018, 07:21 PM   #1
primm907
primm907's Avatar
47
Drives: Cayenne GTS
Supercharged - which engine/trans mounts?
So, I've read through all kinds of threads regarding the "best" setup. From what I can glean, the VT engine mounts and RE tranny mounts seem to be the go-to combo. My question is whether or not I should possibly consider something like 95A poly due to the additional power/twist created by FI. This is strictly a fair weather fun car, but we do also take it on weekend trips from time to time.
The Revshift stuff is pretty inexpensive and offered in both 80A and 95A. Perhaps worth a try...
https://www.bavauto.com/bmw-transmission-mount-ptmbt
Thoughts?
Cayenne GTS - Daily
Macan S - Wife
Panamera Turbo S - Just Sold
M2 - Ordered
      12-02-2018, 07:31 PM   #2
GuidoK
#buildnotbought
GuidoK's Avatar
10855
Drives: Z4 3.0i ESS TS2+
Thoughts?
shore 95a is insanely stiff for a transmission or motormount.
Ok for an all out racecar, but on the street?
Shore 80A will already give noticeable NVH I think.
      12-03-2018, 03:11 AM   #3
2skiddy
Drives: Z4M Coupe
If this is primarily a road car, I would stick with NEW OE mounts, as these will take quite a bit of punishment, as in all the high rev drop the clutch starts and track work, never had a problem. If you want to go for competition mounts, Vibratech do a kit, with a rubber insert harshness option. I went for these as I needed to keep my engine and box down to minimum movement, due to space issues. I could have solid mounted, but I wanted to have a little compliance, not that I will ever go on the public roads with it!
      12-03-2018, 09:48 AM   #4
primm907
primm907's Avatar
47
Drives: Cayenne GTS
Thanks for the feedback. Makes sense!
Cayenne GTS - Daily
Macan S - Wife
M2 - Ordered
