      11-28-2010, 09:42 PM   #23
wrh3
Car Guy
wrh3's Avatar
31
Drives: 2005 MCS, 2013 Corvette 427
I would think the cats on the OE headers/exhaust manifolds generate more heat than headers. I am installing headers on my car right now and had plenty of room and access to go ahead and replace the passenger side mount bracket bolts with BMW MotorSport 10.9 bolts and Nordlocks. The OE bolts were all tight and none were discolored as some I have seen, my car is a 07/2007 build. I think the issue with the bolts is related to a process where they were exposed to excessive heat at some point during assembly after reading the TSB, and that is why we have not seen this issue with the E46 M3s.
Bill- 2005 Mini Cooper S, 2013 Corvette 427
www.billswebspace.com/bmwindex BMW CCA Member # 389948
      11-29-2010, 12:58 PM   #24
boydgti
boydgti's Avatar
Drives: 2007 z4m
mcmaster-carr wont ship to canada, bastards, order on thurs and they tell me today
      12-09-2010, 08:52 PM   #25
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
For what I know is because of heat expansion and not being able to take the load the headers put them thru, and with cat can be hot in there but depending on the headers you use you make closer to the bolts.
But again this is just something that goes around and not a definitive answer to the real cause.
      12-09-2010, 08:58 PM   #26
Drives: M2 Comp
You can get them from Brafasco in Canada.
      12-09-2010, 09:31 PM   #27
boydgti
boydgti's Avatar
Drives: 2007 z4m
to late, shipped them to my parents adress in florida
      12-25-2010, 10:44 AM   #28
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Rogue transmission mounts good? Like it? Pls provide your comments of the differences, etc.
Thanks -
Racerbruce
      12-25-2010, 07:27 PM   #29
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
the difference is def there no more missed shifts for the most part
      11-28-2018, 07:08 AM   #30
JimBob0047
Drives: 2006 Z4MR
Actual current McMaster part numbers:
You'll have to get them from McMaster, but probably more of them than you want, but hey, you can never have too much left over hardware.
You need 6 M8x25 and 2 M8x35 (where the Vanos oil accumulator bracket is attached).
Yea, you're going to get a heck of a lot more of them than you need, but they're dirt cheap.
M8x25 = 90854A167 (Sack of 25)
M8x35 = 90854A172 (Sack of 25)
Nord-Locks = 91812A430 (5 per pack, so get 2 packs.)
