05-07-2014, 01:33 AM | #1 |
Rookie
33
Rep 379
Cruise control not working ... need help debugging
Hello All,
Like the title says, the cruise control in my car doesn't respond to any inputs. I cannot arm the system by using the stalk. I have checked the fuse already (#21) and it's OK. I have also tried to start the car without pressing the clutch in, so I'm assuming my clutch switch is working. My brake lights work fine, so I'm assuming the brake switch is also working. What am I missing here? Are there independent switches on clutch,brake for cruise control system? Thank you, donoman
2003 Z4 2.5i
2013 FR-S 1990 911 C2 1983 Wife Last edited by donoman; 03-27-2015 at 06:12 PM.. |
06-19-2014, 10:07 PM | #2 |
Rep 86
Drives: 3.0si Coupe
Bump, any ideas how to trouble shoot this?
06-19-2014, 11:45 PM | #3 |
703
Rep 7,850
Yes. A BMW scanner is required to read the fault codes. They run about 50 bucks on EBay.
My guess is a faulty module or relay. But diagnosing w/o a scanner, ouch. |
06-28-2014, 02:02 AM | #6 |
Rep 86
Drives: 3.0si Coupe
Any luck Donoman?
06-28-2014, 02:22 AM | #7 |
Rookie
33
Rep 379
I checked for errors, I have 2F67 which is a clutch switch signal. Going to see what's up with that, as it could very well be the reason Cruise isn't working.
2003 Z4 2.5i
2013 FR-S 1990 911 C2 1983 Wife |
07-06-2014, 09:11 PM | #8 |
Mechanical Engineer
96
Rep 1,025
sounds like the clutch switch is bad, so it either (a) thinks the clutch is on all the time, or (b) can't tell when it assumes the clutch is on, so it just assumes it might be on.
I had a similar issue on my Audi where my brake switch was stuck on, so it wouldn't let me initiate cruise control. |
