      06-30-2014, 08:35 PM   #1
Technobuff
Drives: 2004 E85 3.0
03 E85 3.0 driver side window not raising up
Just picked up an 03 E85 3.0 with 97k. Bought the car knowing that driver side window does not raise up. Replaced both window regulator and motor and after installing it, the window glass would go down after I press the window switch to move the window glass upward. The passenger side window glass goes up and down using the other button on the same window switch. I opened up the window switch to make sure that non of th contact ls on the board is bad, everything looks good. Any ideas on the fix? If it requires a window switch initialization, can you provide a detailed procedure. Is it a relay or module issue. Your assistance in advance is greatly appreciated.
