06-04-2014, 10:52 PM | #1 |
Rep 36
Radio wont turn off???
Haven't driven the Z4M in a few weeks, and noticed today, that when i turn off the car, the radio stays on (never did that before). I tried leaving it on, and when i came back an hour later the radio was off--but i could turn it back on (without the key). Anyone had this happen? I plan on disconnecting the battery overnight to see if this fixes.
2006 Z4MR DSP Business radio |
06-05-2014, 12:11 AM | #2 |
Rep 1,134
Drives: '07 M Roadster
might be related to the door switch? do your overhead lights come on when you open the door? If the radio isnt getting the signal from the door to turn off that could do it. I haven't seen my car in a year, but I'm pretty sure they have that function where the radio keeps going after ignition off until the door is opened.
06-05-2014, 09:33 AM | #4 |
Rep 1,247
Mine does not - mine fades out with the key in my 2004. I always wondered why it does not stay on until the door is opened like most cars from that time frame (my 2005 Aviator and my GF 2005 TL both did that) but mine dies either when the key is rotated to the last stop or when it is removed.
In my car anyway.
06-05-2014, 10:00 AM | #5 |
Rep 36
Indeed, mine used to fade out when the key was turned off, but now it stays on even when the door is open and closed. Tried locking and unlocking with the fob and key, but radio was still playing. Weird that when i came back an hour later, the radio was off, but could be turned back on. I believe that prior to this, the radio couldn't be turned back on without the key.
06-05-2014, 09:19 PM | #6 |
Rep 1,034
If you have the Nav it turns off right away, the normal radio should turn off when you open the door.
06-05-2014, 10:04 PM | #7 |
Rep 165
I had issues with my battery dying if I let the car sit for more than 2 days. I ruined 2 batteries in the last year in and a half. It turns out that my radio was not going to sleep - it was pulling a full 2 amps even with the car turned off. Not quite the same issue as you are experiencing, but be careful.
06-06-2014, 03:18 PM | #8 |
Rep 1,247
I do not have Nav in my 2004 and mine dies with the key, not with the door. Mine might be odd, but that is what it does.
06-09-2014, 09:36 AM | #9 |
Rep 36
Well i tried disconnecting the batt overnight, and that didnt work (also found that the PO had replaced the battery with a H5). I eventually pulled the radio, and re-installed it, and that seemed to take care of it
06-15-2014, 10:34 PM | #10 |
Rep 36
Now just today, the AUX input would disappear after being used. All radio functions seem to work fine, but when i use the AUX, it only works for a few seconds, then the AUX option disappears (switches to radio, and AUX is no longer available). Wondering if i should try to find one on eBay?
06-17-2014, 12:51 AM | #11 | |
Rep 1,034
06-17-2014, 10:08 AM | #12 |
Rep 36
Thanks, psygnosis. I am not charging my iPhone, and i tried 2 different 3.5mm cables and 2 different iPhones, with the same result. Its weird that the AUX worked fine for several weeks (just installed it a few weeks ago), and now almost instantly switches to radio when AUX is selected. One weird thing to note, if AUX is selected and cable is plugged into the radio & iPhone, it wont switch to radio until i start playing on the iPhone.
06-17-2014, 10:11 AM | #13 |
Rep 36
Also, does anyone know what the interchange part numbers are for this radio? I have found many different styles of radio that show they will fit but look different and have different part numbers (Mine has a copper back, and several had aluminum fins on the back--and plug oriented 180deg).
06-17-2014, 11:30 AM | #14 |
Rep 1,991
Real OEM shows part number 65129205279 ($581.56 at www.getbmwparts.com). They show five other numbers which say ended for the same radio: 65126976889, 65129130168, 65129136884, 65129150590, 65129189963
06-17-2014, 03:19 PM | #16 |
Rep 1,991
