09-12-2011, 03:40 PM | #23 | |
Rep 313
NS version is mean for special LSD racing application...still some ambiguity that needs to be resolved. In summary, just because you didn't add FM, doesn't mean it's not already included. |
09-12-2011, 06:07 PM | #24 |
Rep 1,991
09-14-2011, 02:25 PM | #25 |
Rep 313
I just got off the phone with my mechanic... how come he's giggling at me knowing I have low miles on my M about changing the diff gear oil? He's a retired BMW master mechanic. I too had the impression that gear oil you change at around 100K miles or so. But reading through all the forums folks recommend 20 to 30K miles. It's cheap to do so it's not the cost, but just like to understand why...and the reason for this whole thread I started.
09-20-2011, 07:01 PM | #27 |
Rep 313
I searched some more and I see that BMW recommends based on the Z4 service checklist that the recommended differential oil change is at inspection 2. I wonder why so many insist on changing at 20 to 30K intervals? Cheap protection?
09-20-2011, 07:56 PM | #28 |
Save the Manuals
1714
Rep 2,937
+1 for Redline, crankcase, MT and diff.
Diff.... I do it at 15k, preventive approach .... I like to drive hard worry free
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
08-23-2012, 11:24 AM | #29 |
Rep 428
So is the Diff drain/fill plugs 14mm?
1997 /// M3 Coupe Arctic Silver CES STAGE IV (651rwhp/615rwtq)
1999 /// M3 Convertible Techno Violet |
09-07-2012, 02:24 PM | #30 |
636
Rep 3,124
Confirmed. 14mm
I was just at Pep Boys and checked the fit, but I didn't buy the socket as it was about 2.25" total length and 1/2" drive. I hear there's a "stubby", or maybe that was only the 8mm for the trans. And I would prefer 3/8" drive if possible. I don't have a suitable 1/2" drive torque wrench. Researching ... Done. Just bought this stubby 8mm from Snap-On,thanks Ron Stygar. And this 14mm from Amazon. Looks about as stubby as they get. Now if someone can recommend a hand pump to get the Royal Purple out of the bottle and into the trans. And what's with the fancy top on the O.E. diff oil? I'd rather not open one yet. Does an easy-squirt tube pop out or something? At $80 a liter it oughta jump out of the bottle and climb in the fill hole by itself. Last edited by StickMon; 09-07-2012 at 11:49 PM.. |
09-08-2012, 09:24 PM | #31 | |
Rep 615
Retired--2007 Z4 M Coupe (Imola Red/Black, Premium Pkg, Heated Seats, XM, Bimmian stubby antenna, CDV delete, Apex EC-7--Anthracite, Goodyear F1 Asymetric 2. |
09-10-2012, 10:12 PM | #32 |
Rep 1,107
A long neck tube pulls out of the O.E. diff bottle. Keep the green cap screwed on and then pull up on it to pull the tube out. It works pretty well. But man, does that stuff smell!
09-11-2012, 06:16 PM | #34 | |
704
Rep 7,850
12-30-2015, 07:55 PM | #35 |
Rep 143
I am a relatively new Owner of my Z4M and I am preparing full fluid changes for Spring as I don't know the fluid change history of my 39K mile vehicle.
WOW! I have had few different performance cars over the years, but I have never seen more confusion than on what Differential Fluid should be in the E46 M3 / Z4M diff. None more so than the dealerships! Friction modifier or no Friction modifier??? LOTS of material to read out there. I've been on Medical time off for the last 2 weeks of the year and I have read enough BMW Differential Blogs to make my head EXPLODE! I seemed to get the most info from all the E46 M3 blogs. I called 2 local BMW dealerships today and they both said 83 22 1 470 080 (SAF-XJ), No FM! One sent me the document he was using as reference, dated 2014. See attached, page 2 of 4. Turner and ECS Tuning both seemed certain that The Z4M Diff needed the FM. Although there are many differing opinions and experiences documented throughout many different blogs, What I have taken away from my research is that I should use a FM version of a 75w/140 Synthetic Diff fluid, despite what the Dealerships are saying. I know this has been Beat to Death FOR SURE! If anyone cares to weigh in . . . Again, feel free Last edited by Bossdog; 12-30-2015 at 08:37 PM.. |
01-04-2016, 05:09 PM | #37 |
Rep 2,665
Recently had service done at Enthusiast Auto. Transmission fluid (Redline MTL), coolant, brake fluid and rear differential. Rear differential - "additive added for limited slip - 505-7478 Diff Fluid Additive".
I had considered doing at least some of the above myself but total parts and labor was about $450 and I decided to let them do all of it. I figured close to $100 in parts and a lot of my time. With the transmission fluid change the shifts are considerably better. I also can't see for $450 for everything worrying too much about stretching the intervals out as far as possible.
