07-14-2012, 10:17 PM | #1 |
Rep 12,565
Calling Detailing Gurus - How to Clean Headliner?
I admit it, I don't always wear gloves when working on the car and unfortunately have some faint spots, prints, stains, etc. on the headliner. I had a cheap can of interior foam cleaner and dabbed a spot only to find out it left a dark stain on the liner. So to all the detailing gurus, what's the best way to get dirt (and failed attempts of cleaning mishaps)?
Quick search shows Folex Stain Remover may do the trick, any other recommendations? Last edited by 3002 tii; 07-14-2012 at 10:43 PM.. |
07-14-2012, 11:04 PM | #2 | |
40
Rep 1,481
07-14-2012, 11:11 PM | #3 |
Rep 175
definitely mist the liner evenly to avoid water spots and wipe in one direction. sometimes misting glass cleaners work well. do not oversaturate or use excess heat, or the headliner will start to fall
07-14-2012, 11:25 PM | #4 | ||
Rep 12,565
Thanks, I just hope the damage has not been done with this interior foam cleaner I tried. I had used it before on the A pillar and it worked fine then but the headliner clearly requires a different approach. The instructions said let it soak for half a min and then rub with the brush head. Seems like it took out the dirt but left a darker stain. |
07-15-2012, 10:34 AM | #6 |
Bad Lieutenant
232
Rep 3,517
It's nylon, which is like a plastic. Use 1Z Einszett's deep plastic cleaner or their cockpick cleaner, it works crazy good, just wipe with the direction of the fibers and finish with a damp microfiber towel. You'll be surprised what is extracted from that liner. I personally don't spray anything while in the car, only onto a microfiber towel.
