      03-31-2008, 04:12 PM   #1
runnerx
runnerx's Avatar
Drives: 06 M roadster; 06 330i 6spd
///M roady 235/265 on stock rim
Hi all,
I need some new rubbers and would like wider tires.. I am currently thinking about 235/40-18 (front) and 265/40-18 (rear) on stock rims. any fitment problems? suggestions are welcomed.
Thanks..
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual
2006 BMW 330i 6spd manual - gone
https://lh5.googleusercontent.com/--bIgrh8ES_s/TxSUCvOmDUI/AAAAAAAAPh0/OOjwrRZtta0/s912/z4mcomparo.jpg
      03-31-2008, 04:23 PM   #2
vachss
Drives: Z4 Coupe
Why go with 40's instead of the stock 35's in the rear. That'll add about an inch of diameter. While I suspect that it will fit, your acceleration will suffer by about 4%.
>> Oops. I'm wrong. See below.
      03-31-2008, 04:28 PM   #3
runnerx
runnerx's Avatar
225/45/18(front) and 255/40/18(rear) are stock on the M roady.
2009 BMW X5 4.8i
      03-31-2008, 04:44 PM   #4
vachss
Drives: Z4 Coupe
OK, thanks for teaching me something. It never occurred to me that BMW would put more aggressive (lower aspect ratio) tires on the non-M, but I guess that's what they do. I guess this compensates somewhat for the higher rear end gearing of the M (3.62 vs. 3.46-3.23 for the non-M).
PS. Given that I wouldn't think the OP would have any trouble fitting the slightly wider tires he's considering.
      03-31-2008, 04:45 PM   #5
MMMazing07
MMMazing07's Avatar
181
Drives: Z4M
i was thinking of running the same setup. Im pretty positive they will fit the stock wheels. Not sure about the 40 offset all around. We need more tire gurus out here
      04-01-2008, 10:22 AM   #6
runnerx
runnerx's Avatar
any tire guru here?
2009 BMW X5 4.8i
      04-01-2008, 11:57 AM   #7
MMMazing07
MMMazing07's Avatar
181
Drives: Z4M
any tire guru here?
I made a thread a week ago about this topic and i got no responses I dont think there too many here. Im going to call tire rack and see what there opinion is. You can go ahead and call if you want. Ill post up here what the result is.
      04-01-2008, 12:13 PM   #8
runnerx
runnerx's Avatar
I emailed Gary@tirerack yesterday, he also is the moderator of E90post Tire and Wheel section. Hopefully, he can shed some light on this for us.
2009 BMW X5 4.8i
      04-01-2008, 01:23 PM   #9
Rick Hunter
Skull Squadron Leader
Rick Hunter's Avatar
307
Drives: '07 M Coupé & '16 435xi GCoupé
Hi all,
Thanks..
Tires will fit on the rims.
Here's your bible. http://www.carbibles.com/tyre_bible.html
      04-03-2008, 10:17 AM   #10
runnerx
runnerx's Avatar
thanks guys. I ordered Goodyear Eagle F1 Asymmetrics 235/40-18 and 265/40-18 for my stock rims. hopefully there won't be any rubbing. I will let you guys know later.
2009 BMW X5 4.8i
      04-04-2008, 04:01 PM   #11
chris719
Drives: '08 M Roadster
Correct me if I'm wrong, but the diameter of that setup does not match stock, so the speedometer will be off by a few percent. Does this change the way DSC behaves?
      04-04-2008, 10:53 PM   #12
runnerx
runnerx's Avatar
yes, at 60MPH, the front would be about 59ish and the rear would be 61mph.
the diameter change is still less than 3%, so it shouldn't cause any problem with DSC.
2009 BMW X5 4.8i
