      06-18-2012, 01:59 PM   #23
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
yeah... I have a hole there, running 265s. heh
      07-15-2012, 04:44 PM   #24
kklin
Drives: BMW Z4 M Coupe
We broke one of the rear Apex wheels on a curb at our previous event, so since the rear always wants to step out, I max'ed the rears from 265/35 18 to 275/35 18 Star Specs. 5mm H&R spacers were also needed.
Alignment is max'ed as follows on OE suspension:
Front : Left
-1.4 Camber
0.11 Toe
Front : Right
-1.4 Camber
0.13 Toe
Rear : Left
-1.4 Camber
0.10 Toe
Rear : Right
-1.4 Camber
0.12 Toe
Car doesn't feel much different on autocross today. Still need to be on your toes with DSC off and Sport on.
      07-18-2012, 11:50 PM   #25
kcdedric
kcdedric's Avatar
Drives: E90 M3
Do you have any pics of your entire car just standing still? I'm considering picking up a set of aggressive fitment Apex's and would like to see how they look on your OE suspension with the car as a whole.
Le Mans Blue '09 BMW M3 Sedan - Current
Polar Silver '04 Porsche GT3 - Gone
Persian Blue '08 Lotus Exige S240 - Gone
Space Gray/Imola '08 BMW M Coupe - Gone
      07-19-2012, 08:30 AM   #26
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
Why do you run with sport on? It seems to make the pedal way too sensitive IMO.
      07-19-2012, 07:35 PM   #27
kklin
Here's a quick phone pic ...
      07-19-2012, 07:49 PM   #28
kklin
Just trying to get on the throttle early. Besides spraying and dropping pressures between runs, I tend not to adjust much during the day.
I should probably try early runs with Sport off to see what its like. First time I pressed Sport was I think on the 3rd run of our first event with Roffle Waffle riding along - I asked him what "this" button does. Only 4 runs during our last event (part of Al Holbert memorial) so I didn't experiment. In the event before that, I had my son drive with DSC off - he looped it and broke one of the Apex wheels, so I only had 1 run.
      07-19-2012, 07:56 PM   #29
Kgolf31
Kgolf31's Avatar
460
Understandable.
I had a real hard time doing throttle modulation with it when I had it on...really touchy.
      07-20-2012, 07:38 AM   #30
AUTOX08MC
AUTOX08MC's Avatar
Drives: 16 M4
Sport off will make you much better....
2016 BMW M4 MW 6SPD,2005 Honda S2000
2014 Subaru STI (Sold),2008 BMW Z4 MC (Sold)
2012 VW GTI (Sold),2006 Subaru STI (Sold)
2003 Subaru WRX (Sold),1996 Mustang Cobra (Sold)
1986 Dodge Shelby Charger (Sold)
      07-20-2012, 10:35 AM   #31
ZStig
279
I've ridden along with kklin and he does fine with throttle modation with the sport on.
      07-20-2012, 01:13 PM   #32
Kgolf31
Kgolf31's Avatar
460
I'm sorry, but that's hard to believe.
There is no modulation with sport mode. It's literally stupid. On or OFF. You decide within 2cm of pedal travel.
      07-20-2012, 02:49 PM   #33
AUTOX08MC
AUTOX08MC's Avatar
Drives: 16 M4
His results do not indicate that he is doing "fine"....
      01-25-2016, 11:40 AM   #34
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
This thread is VERY old but I'm hoping OP or someone with similar specs can confirm...
265/35/18x9.5 ET30 (including 5mm spacer) does not rub the fender at all in the front with ~-1.4* camber at autocross? That is really surprising. If that's the case I may be doing something similar but in 255/40/17x9.5 ET30 (including spacer) with -2.7* camber.
      01-25-2016, 12:10 PM   #35
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I'm running 265 on 9.5 wheels total offset of 30 (wheel & spacer)
My camber is 3.2 and I have caster maxed
Max caster makes a big difference with rubbing at the spot where bumper meets fender.
I have zero rubbing with this setup.
http://www.zpost.com/forums/showthread.php?t=1181957
