07-29-2022, 07:58 PM | #1 |
Rep 1
Differential 3.0l vs 2.5l
I need a differential for my 2003 Z4 3.0l Automatic. Are the differentials in the 2.5l different than the 3.0l? I see that they have a different part number. I have tried searching this forum but have not come up with this particular answer. Thanks in advance.
Whining in Savannah, Jay |
07-29-2022, 08:22 PM | #2 | |
Rep 2,705
In my experience there is no physical difference between 2.5,3.0i or 3.0si diffs, auto or manual. there are different final drive ratios. Highlighted in yellow here.
07-30-2022, 10:45 AM | #3 |
Rep 5,329
in that case can you guys put in the ///M unit ?
07-30-2022, 02:09 PM | #5 |
Rep 2,705
I wish it was that simple Byron. Alas no.
Takes substantial mods. IE subrame etc.
07-31-2022, 05:05 AM | #6 | |
#buildnotbought
10958
Rep 4,910
Not only has the M diff different mounting points in the subframe, it also has different input and outputflanges, (which cant be swapped out) and the M driveshafts wont fit the non M trailing arms. Of course if you start off with a 5 speed or automatic, the M propshaft has the wrong lenght, so only a 3.0i/3.0si is really suitable for this conversion.
