      09-10-2008, 07:50 PM   #1
Z FORE
Z FORE's Avatar
Drives: 2010 E93 Convertible
What wheel set-up?
I have an 06 3.0i Roadster that i want some new shoes for. My current (OEM) set-up is 225/45/17 on the front and 255/40/17 on the rear. I like the fact that there is not much gap at the top of the tires to the fender.
I am considering some 18" or 19" CSL type wheels from Velocity and need some recommendations on wheel and tire size. I would like the rears a little wider if possible. I would also like the wheels to stick out maybe 1/2 inch more.
Any suggestions? Anyone have a picture of hyperblack CSL wheels on a Ti Silver Z?
Here is what my current set-up looks like.
      09-11-2008, 05:59 PM   #2
Z FORE
Z FORE's Avatar
No recommendations or advice?
      09-12-2008, 01:00 AM   #3
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
Do you have the sports package? If you go to a 18" or 19" wheel your wheel gap will get bigger (space between top of tire and fender) You will end up with the lifted Z4 look until you live with it or decide on some suspension work. The Z4 has nearly the same offsets as the E46 coupe so the staggered 18" / 19" in Non-M fitment will be perfect. 18x8.5 ET40 and 18x9.5 ET45
      09-12-2008, 10:00 AM   #4
3002 tii
3002 tii's Avatar
2288
agreed unless you have the sport pkg, dont go bigger or you'll have the 4x4 look. i'm upgrading shoes too but sticking with 18s (car came with 18s), plus anything biggger just isn't practical... cost of tires, ride quality, mileage, etc.
Follow for latest mods
      09-12-2008, 03:13 PM   #5
Z FORE
Z FORE's Avatar
I do have the Sports Package and mine came with 17's. I can't go to 18's w/o making the gap bigger? Why is that?
      09-13-2008, 04:18 PM   #6
BimmerZealot
I dont know the exact explanation behind it but I think it's because when you increase the size of the wheel, the distance from the center to the edge of the tire gets larger. Thus your car will sit higher off the ground then it did before, creating a larger gap. Also with bigger wheels you'd run lower profile tires therefore filling in less of the gap. If you want to go to 18" you're going to need to lower your car, simple as that. Or live with the gap.
      09-13-2008, 08:18 PM   #7
GP20
Actually, on the Z4 & using the front as example, if you go from 225/45/17 to 18" wheels (225/40/18) or 19" (whether 225/35/19 or 235/35/19), the wheel gaps actually become smaller as the tire radius/diameters increase. It's the optical illusion that fools your eyes into seeing bigger wheel gaps. Even worse (bigger wheel gaps) when it's deep-dish wheels like my RGR's compared to wheels like the M6 replicas or CSL's/ZCP's.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      09-14-2008, 07:20 AM   #8
Z FORE
Z FORE's Avatar
Would a set-up like this add to my wheel gap? I do not want to lower the car but want to add some new wheels.
http://www.europeanautosource.com/pr...oducts_id=1405
      09-15-2008, 03:11 AM   #9
BimmerZealot
GP20: I had no idea, I thought it was the other way around. Good to know.
      09-15-2008, 09:59 AM   #10
Burt Reynolds
Burt Reynolds's Avatar
53
Drives: 2007 M Coupe
I did not know either. Optical or not though, go plus size and a drop works well
