      06-02-2023, 04:22 PM   #1
Semp
Semp's Avatar
16
Drives: 07 M Coupe
FS: Apex SM10 Satin Black 18x9.5 et22
Selling a set of Apex SM10 in Satin Black squared
Used for 3 track events and its mounted on Pirellis.
1 wheel has some chips.
Asking $800
      07-30-2023, 07:54 PM   #2
Semp
Semp's Avatar
16
Drives: 07 M Coupe
Updated
      08-05-2023, 09:17 PM   #3
Z4M06
Drives: 2006 black Z4 M
I’ll take it, if it’s still available.
      09-12-2023, 10:45 AM   #4
Semp
Semp's Avatar
16
Drives: 07 M Coupe
Still for sale
      09-13-2023, 07:05 AM   #5
pcube
pcube's Avatar
58
Drives: Z4MC, G20 320i
Just curious, did you need a lot of negative camber to fit these on the front? Those specs look like they are meant for the rears.
      09-13-2023, 07:02 PM   #6
Semp
Semp's Avatar
16
Drives: 07 M Coupe
My car is a track dedicated car but I still drive back and forth to the track. I am running 3.7 neg camber in the front and zero rubbing. I moved up to a set of 18x10 et25's (squared) and no rubbing as well.
      09-14-2023, 03:10 AM   #7
pcube
pcube's Avatar
58
Thanks, good info for reference. I assume you're on camber plates as well. Without those, unlikely we can get more than 2 deg negative camber even with the pins removed.
      09-14-2023, 09:35 AM   #8
Semp
Semp's Avatar
16
Drives: 07 M Coupe
That is correct, ground control camber plates on MCS 3 way coilovers.
