09-05-2015, 01:40 PM | #1 |
Rep 12,565
Has Anyone Replaced Differential Bushings?
Referring to parts 7 and 9 below. Is this a DIY or major PITA and better left for an indy shop?
09-05-2015, 02:26 PM | #2 |
#buildnotbought
10838
Rep 4,891
I replaced it twice....
The first time (the original bushing) was less stuck than I had expected. But I had the rear axle off the car. But if you use the factory tool, that shouldn't make a difference. If you use generic press/pullers space might be an issue. I thought it was a diy job, but I think everything is a diy job. But imho you need a carlift and a transmission jack as the diff has to come out (although I know people who swap z4 diffs on their port without a lift, just on jackstands or so....)
09-05-2015, 02:42 PM | #3 | |
Rep 12,565
09-05-2015, 04:38 PM | #4 |
#buildnotbought
10838
Rep 4,891
If you have the bmw tool (that allows you to remove it without dropping the subframe), removing and installing the bushing is 15min work or so when the diff is already out.
You place the press tool, and start winding the nut on the threaded bolt of the tool.
09-06-2015, 12:15 PM | #5 |
1621
Rep 4,294
My indi dropped the whole sub frame, I had all bushes replaced.. did it while the whole car was apart.. :-D
Only way to be sure, take off and nuke the place frome orbit. |
09-06-2015, 01:11 PM | #6 |
Rep 2,782
Does this mean you're buying that 30/90 3.91 before I have the chance to snatch it up??
09-06-2015, 01:28 PM | #7 |
Rep 12,565
Negative, the 3.91 is all yours
