      08-27-2015, 11:14 AM   #1
tkeneklis
Drives: 2005 Z-4 roadster
2005 BMW Z4  [0.00]
Dash Rattle
I have a dash rattle that drives me nuts. When I go over bumps or hit a pot hole I get a noise like two small brass cymbals and hitting each other. It seems to come from the instrument panel. I have read posts on struts and others but this seems like a new one. Who can help?
      08-28-2015, 06:51 PM   #2
Clearancediver
Drives: 2004 Z4
Tighten/retorque the strut races in the engine compartment. It costs nothing to do and likely will fix the problem. If it doesn't you've eliminated a potential cause ...
Sent from my smart phone...
      08-28-2015, 08:55 PM   #3
tkeneklis
2005 BMW Z4  [0.00]
Thanks I will try that.
      09-02-2015, 04:32 PM   #4
tkeneklis
2005 BMW Z4  [0.00]
I tightened them but still get the rattle. Any other suggestions?
      09-02-2015, 10:39 PM   #5
Clearancediver
Drives: 2004 Z4
Honestly can't think of anything else in dash area that would cause a sound. I would suggest you check your suspension and anything connected to the control arms. Worn bushings etc may be the cause. It also could be your struts are worn out ... So check the front springs to see if you have any issues there caused by bottoming out the struts...
      09-03-2015, 07:35 AM   #6
JCF
Drives: 07 Z4 M Coupe
The instrument panel is only held in by one screw. Easy to pull out and see if there is anything back there rattling around.
      09-04-2015, 12:16 PM   #7
tkeneklis
2005 BMW Z4  [0.00]
Where is that screw?
      09-04-2015, 12:17 PM   #8
tkeneklis
2005 BMW Z4  [0.00]
I have had the struts and shocks replaced but to no avail.
      09-04-2015, 03:47 PM   #9
JCF
It's a torx screw
tilt the wheel down and fully out--look up at housing and see the single screw --remove it and pull towards you.
You don't need to unplug the cluster, there's enough room and slack to shift it around and see if there is anything loose.
      09-05-2015, 12:20 PM   #10
tkeneklis
2005 BMW Z4  [0.00]
It's a torx screw
Clean up behind the instrument panel of dust etc. found nothing that would rattle but found nice places to hide cash and pistol.
      09-05-2015, 12:38 PM   #11
JCF
If you have some help, are you able to replicate the noise by having someone bounce the car with their weight?
Next thing to check, if you're sure it's coming from the dash, is to pull the radio and see if there's something back there.
/// LED Lighting /// Pedal Haus M aluminum pedals and heel plate /// BMW logo puddle lights /// CF wrapped console /// LeatherZ MK4 console storage, armrests, door pulls /// ZHP illuminated shift knob /// BMW under seat storage /// Soundplicity III /// Stubby Antenna /// Eventuri Intake /// Tekcarbon CF valve cover /// Stromung exhaust /// Rogue Engineering Transmission Mounts ///3rd brake light blinker
      09-05-2015, 02:50 PM   #12
Sterling Roadster
Drives: e85 Z4 3.0i & e92 328i
As I understand it, when strut bearings fail they make a noise similar to what you have described. Otherwise, i'd be checking for loose metal in the engine bay, or possibly a heat sheild somewhere.
      09-05-2015, 03:42 PM   #13
tkeneklis
2005 BMW Z4  [0.00]
Pulled the vents and radio and all I found was dust and better places to hide a revolver when crossing state lines.
Tags
dash rattle
