      05-26-2013, 02:37 PM   #45
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Originally Posted by Quickid View Post
Grime in lugs is not a highly likely candidate for ticking noise from the rear. I know we're basically just guessing based on your observation but I still believe it's your differential. I can't say exactly what's wrong but the way you described it as sounding like zip ties getting repeatedly reminds me so much of how my diff sounded.
Good luck. Hope you figure it out soon!!!
Thanks. I suppose worst case = get the diff opened up and/or rebuild. No tracking for a while
Sad, because it's finally summer and perfect time for track...
      05-30-2013, 07:49 PM   #46
wss4
Drives: 2008 Z4 M Coupe
Very curious to see what you find out. I was having similar noises at the track under heavy, high speed cornering loads last time. Am going back out this weekend, with new suspension (lower w/ more camber) and new brake pads. Will see if noise persists.
My money is on a wheel bearing if the noise is still there.
      05-30-2013, 09:38 PM   #47
mfanatic325
///M-fanatic
Taiwan
193
I just got the car back from the shop. Haven't heard anything major yet, albeit it was only a short drive home, and I was more preoccupied with getting the car to a friend's house to use some pressure washers and spraying the car down. Oil spills in the engine bay are NOT cool...gets every nasty as hell
Will report back after more daily driving. Going to the steam cleaner tomorrow to get the engine bay and underpanels a proper cleaning.
      06-03-2013, 03:10 PM   #48
mfanatic325
///M-fanatic
Taiwan
193
I haven't heard much if any ticking since getting the car back from shop. I do recall a lot of noise when the car came off the track last Saturday though.
Will continue to look out for ticking and report back if I find anything.
      10-31-2013, 09:34 PM   #49
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
any update to this?
i don't have ticking, but i have been noticing increased road noise in the past 6 month, just curious as to what was going on with your car so i can watch out for it.
      10-31-2013, 09:59 PM   #50
wss4
just had rear wheel bearings replaced at around 60k miles. i was experiencing ticking under high speed, high load corners at the track. dramatically less road noise now.
      10-31-2013, 10:03 PM   #51
jdoublehcubed
Mechanical Engineer
What was the cost?
Assuming you had a shop do it, everything I read says these are a huge bitch to DIY.
      11-01-2013, 02:42 PM   #52
wss4
$700 out the door
      01-03-2014, 08:58 AM   #53
mfanatic325
///M-fanatic
Taiwan
193
Oops, forgot to update the thread. I asked another shop for their expertise on my ticking noises, and they believe it's my LSD as well. Looks like I'll have to go Quaife or OS Giken next Can't believe OEM is so weak..sigh! I seriously doubt I'm tracking any harder than others here -_-..
      01-24-2014, 08:47 AM   #54
3002 tii
3002 tii's Avatar
2282
I know this wasn't actually the wheel bearing but turns out I had to replace my front left wheel bearing after 35 track days and not being shy with the curbing. Right side still seemed ok. Also had to replace both control arms since there was play in the ball joints. Fun times.
Follow for latest mods
