      01-05-2015, 06:27 AM   #23
SlickShift
SlickShift's Avatar
No_Country
323
Drives: '11 BMW E90 M3 ZCP, '21 X5 ZMP
Originally Posted by gmd2003 View Post
In my case it was fuel starvation but it was from undersized injectors . Test you're fuel pressure and make sure that is adequate as a starting point . Are you stock , tuned , FI ?
I'm basically stock. Just intake and mufflers.
-Nick
2018 BMW 440i - M Sport, Exec
Glacier Silver Metallic/Coral Red Dakota
Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i
      01-09-2015, 08:57 AM   #24
gmd2003
gmd2003's Avatar
352
Drives: 2014 CP M6 and 2006 VT 525 Z4M
I would recommend changing out your fuel filter if you're car has higher miles . Any codes stored in the ECU ?
      06-06-2016, 08:07 AM   #25
longress
longress's Avatar
Drives: 2007 Z4M Coupe
This thread died without a response. gmd2003 was this fuel related? Did your limp mode ever reoccur?
Thanks
      06-06-2016, 08:32 AM   #26
wdb
dances with roads
wdb's Avatar
4722
He did post a reply, said his problem turned out to be undersized injectors. This makes sense to me based on my time spent in the STi forums, where folks would need bigger injectors when bolting on bigger turbos.
General note: Lean condition on boosted engine = excellent way to break expen$ive part$.
      06-06-2016, 09:17 AM   #27
VMZ432
Fast Everything
Drives: Z4MC
Thanks
I can tell you the larger injectors and newer tune completely solve the limp mode issue. I was getting it multiple time per track day, and have not had it since in 3 or more days. However overheating is still a big issue, despite larger oil cooler, colder plugs, and Zion radiator. I need something more here. Possibly it is related to the removal of the air box allowing too much air to bypass the radiator. I'm still trying stuff. Will report back, but I'm not rolling much ATM. Partly due to the supercharger belt self destructing, but mostly due to me being lazy about getting her fixed.
2006 IBlue BMW Z4 MC - ESS VT2-525 Supercharged, JRZ RS1 suspension (500#F, 600#R) with Vorshlag plates, ST Trophy BBK with CL R6E pads, KKS gated exhaust, TMS sway bars, RE rear camber arms, VT engine mounts, Recaro Pole Position (driver), APR GT wing, Street: Volk G2s and Potenza, Track: Volk TE37SLs and BFG R1s.
      06-06-2016, 11:37 AM   #28
longress
longress's Avatar
Ok thanks.
This issue just popped up last weekend at the track on my NA Z4m. My first thought was fuel. I need to check pressure and I'll probably put a filter in and retest. I have no engine mods (all brakes and suspension) so bigger injectors would probably not be as much of a possibility for me.
      06-06-2016, 12:06 PM   #29
gmd2003
gmd2003's Avatar
352
Thanks
Yep the bigger injectors 100% fixed the FI induced limp mode on track for me as well . If you are having the same issue I'd check the fuel filter first and if that's never been changed replace it , as a clogged filter could be an issue even on an NA car .
