08-09-2010, 01:57 PM | #155 |
Rep 4,320
Drives: '07 Z4 M Coupe
Can someone who's purchased this $38 alarm chime in?
1. Will it work in an 07 Z4M coupe as well as an 06 Z4M roadster? 2. Does it include the incline sensor; or does it only monitor the doors/hood?
08-09-2010, 02:02 PM | #156 |
Rep 1,110
works in my 07 m coupe, not sure about the 06 roadster. does not include the incline sensor.
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 * '14 Jeep Grand Cherokee Overland Hemi... No more snow for the M! |
08-09-2010, 02:34 PM | #157 |
Rep 11,667
^whs
works perfectly in my M Coupe, including activation.
08-09-2010, 02:59 PM | #158 |
Rep 4,320
Does this alarm include the incline sensor?
Trying to figure out what the difference is between the $38 alarm and the $120 one.
08-09-2010, 03:15 PM | #159 | |
Rep 11,667
I think it's all in this post.....
08-29-2010, 09:54 AM | #160 |
Rep 5
Alarm Fully Functional
I bought the cheap kit from Tischer and it did nothing, no chirp on lock or unlock. I tried disconnecting the battery & reinstalling with no luck. I took the car to my independent BMW guys, Shade Tree Garage in Raleigh, for another issue and they activated the alarm for free. Works perfectly now. Now if only the damn car would start when hot I'd be money. The car has 27,000 miles and will be on it's third fuel pump.
08-29-2010, 10:03 AM | #161 |
Rep 11,667
I thought I had a problem with my system the other day.
It had been activated & working perfectly to that point. When I locked the car I wasn't getting the chirp; unlock got the 2 chirps OK. It turned out the the passenger door was not fully closed. It's a feature I didn't know about.
08-29-2010, 11:38 AM | #162 | |
Rep 352
OEM Strut Brace / UUC SSK / Zeck CDV / Clutch Stop / ZHP Shift Knob / Stubby Ant / Top Covers / Dinan K&N / M Seats / SP / PP |
08-29-2010, 06:09 PM | #163 | |
Rep 647
09-02-2010, 12:00 AM | #165 |
Rep 2,866
An Update...
Finally got my alarm chirping and working properly after encoding. What a hassle for something that should be considered "routine"...left it at the dealer for 3 days before they finally got it right (4 days if you count the first time I took it in about a month ago). They finally gave up and had to put in a case with BMW for help. Essentially, they have to Disabled everything on the CKM coding (I believed it's the Car Key Memory coding), then Re-Enabled everything to get things to work properly...just a heads up for anyone who can't get the single "chirp" to work after encoding. |
09-02-2010, 07:24 AM | #166 |
Rep 11,667
Glad you got it working.
I can't understand why some are a problem & others are a breeze.
09-02-2010, 07:34 AM | #167 |
Rep 2,138
Drives: Me
Something else I found out.
I pressed the release for hatch, then got out. Closed the door and locked the car. Did not hear a chirp, then remembered the last couple of post here. Removed what I needed from the trunk and shut the hatch. As soon as the hatch closed, the car beeped, letting me know the car is NOW locked. Cool... |
09-02-2010, 07:37 AM | #168 |
Rep 11,667
09-02-2010, 07:53 AM | #169 | |
Rep 421
09-02-2010, 08:04 AM | #170 |
Rep 2,138
Drives: Me
Yes, but did not beep. Once the trunk closed, the car beeped.
I just walked out the the parking lot to check. yes, the car doors lock but no beep. Open hatch, close hatch, car beeps. |
09-02-2010, 08:10 AM | #171 |
Rep 11,667
^ Same scenario with me when the passenger door was ajar.
09-02-2010, 09:33 AM | #172 |
Rep 2,866
Anyone found that when the alarm is armed, you can't use the remote to just open the hatch? You have to disarmed the alarm first before the remote will open the hatch. This is different than what I'm used to in my X5, which would allow me to open/close the hatch using the remote without having to shut off the alarm first. As a matter of fact, most of the other cars I've owned operates like the X5. Something I'll have to get used to, I guessed
09-02-2010, 09:40 AM | #173 |
Rep 2,866
Good to know that it will arm the alarm only after everything has been shut...nice subtle feature!
09-02-2010, 10:20 AM | #174 |
Rep 421
Same with the hood. I leave it unlocked in the garage so I can unhook my CTEK when I leave.
10-02-2010, 06:44 PM | #175 |
Rep 199
Well I just attempted this install on my 03 3.0i and sad to say that it did not fit... looks like i need part number 65758383153 which runs $141.92 just for the siren.... wtf! Has anyone with a late 02 early 03 build z made this work for them?
10-20-2010, 11:08 PM | #176 |
Rep 16
I am in the same boat, as my Z4 was produced in 11/2002. I need the retrofit instructions as the above pdf pics are blacked out. Or even better, a way to make the 40 dollar alarm work.....Thanks
