      08-02-2019, 11:15 PM   #1
dre99gsx
Drives: 1994 Toyota Supra
Diff rebuild - installing C-clip (shims) and preload
Having trouble creating carrier preload with the 188k shim (c-clip). As soon as I build up the shims or use thicker C-clips to try and get a few extra in-lb of preload on the carrier, I can't get the c-clip to seat into the groove.
If I hammer / punch it in, then it's a nightmare to remove with my heavy duty c-clip remover
Any tip on doing this? I am tempted to get it under a press to apply some amount of pressure on the carrier while I try to seat the C-clip, but there must be an easier way.
      01-07-2020, 10:22 AM   #2
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Did u figure this out yet? Doing mine soon.
