      04-07-2017, 10:52 AM   #1
comics69
France
80
Drives: Z4MC
Who has already fitted status gruppe headers ???
Hi guys,
Just received my header from Status Gruppe, but it seems to don't fit correctly...nothing is plug and play, both for engine side and exhaust.
And i didn't know we have to weld the fixation on the header for the downside (to the catalyser)...
Check the pic attached....
What is wrong ? I thought this header was plug and play!!
      04-07-2017, 04:17 PM   #2
David70
When you try to push it flush with the block, what stops it from going?
      04-07-2017, 04:40 PM   #3
VindieselJetta
Drives: Z4m
Considered these, glad I went with Euros. Hope you get it worked out OP!
      04-07-2017, 05:54 PM   #4
Mirko
Mirko's Avatar
I don't have these headers but is the little nub on the transmission causing you problems? You might have to file it down. I had to wiggle around and play with it a fair bit to get my fabspeed ones to settle. It's an awkward shape and area to work with.
      04-07-2017, 10:41 PM   #5
zurus
Puerto Rico
49
Drives: IB M coupe
Been running them for over a year with no problem, try removing and refitting again
      04-10-2017, 10:07 AM   #6
comics69
France
80
Drives: Z4MC
thanks for your reply guys.
here you are some pics..
Nothing is going well, the header is not aligned with the rest of the exhaust, even if i cut the tab on the transmission..
it is really strange, as if the header was not designed for this car, but after some email with SG, they told me they have only one model, so no possibility they switch with another order...!
Check this out....
Moreoever, i didn't know we have to weld the fixation to the cats section...
      04-10-2017, 10:09 AM   #7
comics69
France
80
Drives: Z4MC
did you see the position from the engine side when i align the header to the cats side ???
      04-10-2017, 12:08 PM   #8
Steeler
Steeler's Avatar
2429
May be a dumb comment, but could you have the banks switched??
      04-10-2017, 12:14 PM   #9
comics69
France
80
Drives: Z4MC
What is banks? U mean header?
      04-10-2017, 02:27 PM   #10
Steeler
Steeler's Avatar
2429
Yes 2-3 pipe pieces. Maybe have front and rear mixed up.
      04-11-2017, 12:56 AM   #11
zurus
Puerto Rico
49
Drives: IB M coupe
You dont have to weld anything, did they not include the slip on flanges with the headers??
      04-11-2017, 02:09 AM   #12
comics69
France
80
Drives: Z4MC
i have only this part in the box ...
how can i hold the header to the cat section without welding it ???????????? sorry but it seems really strange.....!
      04-11-2017, 02:36 AM   #13
zurus
Puerto Rico
49
Drives: IB M coupe
You slip 1 flange on each of the header ends and put a new seal and tighten it up. No welding required.
      04-11-2017, 03:03 AM   #14
comics69
France
80
Drives: Z4MC
you sure it will be no leack with a such way ??
In any case, thanks to your reply...
But the most important point is : why i cannot fit the header correctly... ?!!!
      04-11-2017, 04:03 AM   #15
zurus
Puerto Rico
49
Drives: IB M coupe
I'm pretty sure that you put them on wrong like dbarton said, switch them around and see if they fit.
      04-11-2017, 11:51 AM   #16
Cyclops
Cyclops's Avatar
Are you righthand or lefthand driver? These will not work with righthand drive as it interferes with the steering column.
From everything I've read online these are pretty straight forward to install so either your doing it wrong or something is wrong with the header.
I ordered a set and I'm still waiting on them so I don't speak from experience. However, I would worry about trying to line them up with section one, get them on the block and on the bolts first one piece at a time. I'm not sure which piece is easier to go on first but I'd assume you should start with the rear piece (short unit, I think you have them on right) then the front (longer). Once on the blots hand tighten the nuts and try to line up the header to section one. Looking at your hardware you're missing a seal that goes between the flange (those circle things). If you still can't line these up maybe they got bent in shipping. Best thing to do is to compare you unit to the photos on SGT website and see if there are any discrepancies.
You can reach out to No_Dominion as he installed his without a problem. He also followed this Step-By-Step Guide.
You can also check out the Euro header install for tips here.
Good Luck
I hope I don't have these issue when mine arrive.
- Instagram ->@e91kiter
      04-12-2017, 08:47 AM   #17
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I have Fabspeed and section 1 clamps are the same way.
They work fine once you have the gaskets in place and clamp them up.
It's actually a benefit as it makes fitment easier to set the length.
I know France is left hand drive , so that is not a problem.
It should be obvious which one goes to front (cyl 1-3) and which goes to back.
They are hard to fit if you try put them in one at a time.
What works best is to hold both parts at the same time in the correct orientation and then slide them in together.
Also....
The headers do not cross over as the OE headers do where they connect to section 1
so now left and right side are reversed.
If you are using secondary O2, they need to be switched over as well.
      04-26-2017, 09:10 PM   #18
Cyclops
Cyclops's Avatar
comics69 just wondering what was the final out come of the install?
      04-27-2017, 02:33 AM   #19
comics69
France
80
Drives: Z4MC
I finally fitted them with sucess, but with some modification.... nothing is impossible
Update will arrive soon
      05-28-2017, 11:28 AM   #20
Csa225
Drives: 07 M Coupe
Hi guys,
I got the heat protected status Gruppe headers and the race cat section after that and had no fitment issues. Hmmm, not sure what the problem would be but they were pretty good with customer service.
      01-24-2020, 10:01 AM   #21
filtercoffee
I like Coffee & Z4s.
106
Drives: 2007 Z4MC
2007 BMW Z4MC  [0.00]
My SGT headers had no fitment issues. I was also confused about the flang thing. Called SGT and they said no need to weld.
Pic attached
