      01-27-2021, 07:59 PM   #1
lafuerza
Drives: 2007 Z4M Coupe
Z4M Skid Plate???
Does anyone make a Z4M skid plate? Had one on my e36 m3 and it worked very well. The Z4M is unique in the way its setup. Anyone have experience.
I currently have the MFR splitter. I want something that closes up the pulleys so I don't get stuff flying in there. I also have a 1M bumper installed.
MFR Engineering Chassis Mounted Splitter and Side Skirts
https://mfrengineering.com/collectio...front-splitter
Debating just buying OEM Z4M belly pan but its almost as much as the E46 M3 metal skid plates.
Any input would be good.
2007 Z4M Coupe. KW3, Stoptech ST60/ST40, SSK, AKG Bushings, 4:10 Diff, ARP Wing, ARP Splitter, MFR Splitter Underpanel.
      01-30-2021, 04:00 PM   #2
wdb
dances with roads
wdb's Avatar
4732
The Z4 has a "skid plate" by design. I don't believe the E36 is similarly constructed. It's called a 'reinforcement plate', it's made of thick-ish aluminum, it's held in place by quite a few quite stout bolts with quite high torque settings, and it not only protects the underside but also ties various bits of same together. Oh and the front jacking point sticks out the bottom of it.
https://www.realoem.com/bmw/enUS/sho...diagId=31_0779
      02-11-2021, 12:34 AM   #3
lafuerza
Maybe I mispoke. I am looking for the piece that goes from the bumper to that skid plate your talking about that covers the steering rack, etc. Its in front of the part your referring too.
      02-12-2021, 06:03 PM   #4
sikedsyko
Drives: 2005 Z4
The forward plastic undertray is a pretty simple piece. You could probably make your own out of a sheet of aluminum pretty easily.
