      05-08-2020, 11:04 PM   #1
flyzipper
flyzipper's Avatar
Drives: 2008 M Coupe
Winter wheels in spring (also... M Double Spoke 164 experience?)
I know it's spring, but my current winter set has a cracked wheel, so... planning ahead.
Background
I've been using the original OEM M Double Spoke 224 for my winter tire set, but cracked one of the rears and it needs to be fixed or replaced.
Tires are Michelin Pilot Alpin PA4's in 245/40/18 (which are spec'd for an 8 - 9.5" wheel width).
Options
0) Get the cracked wheel welded ($300 estimate from local shop)
Pro: least expensive (works with current wheels and tires)
Con: shop hasn't seen it yet (might eliminate this option entirely if not fixable)
Con: feels janky
Con: wouldn't inspire confidence driving drive around on a welded wheel
Con: reliability of my car is important (it's my daily)
Con: read some welding forums (mostly a mix of novice welders looking for advice for their technique, and experienced welders saying they never weld aluminum wheels so they can sleep well at night).
Con: a blow-out wouldn't be fun
Con: dying
Con: lots this option has the most cons
1) Buy a new OEM 224...
https://shop.bmw.ca/p/BMW_2008_Z4-Co...107841691.html
Pro: inexpensive (works with current tires)
Pro: simple
Con: expensive (almost $900CDN per wheel)
Con: new wheel joins a set of 12 year old wheels
Con: continues to be staggered wheel setup
Con: need to stay with 245, 255 or 265 winter tires
2) Buy new set of OEM 164's...
https://shop.bmw.ca/p/BMW_2008_Z4-Co...117836851.html
Front - 18x7.5ET41
Rear - 18x7.5ET20
Pro: inexpensive (less than $300 CDN per wheel)
Pro: enables the use of 215 or 225 winter tires
Pro: enables a naturally square setup
Pro: 4 new wheels replace 4 12 year old wheels
Con: current 245/40/18 tires are a little wide and would need a new home (or be retired).
Con: expensive (requires a whole new set of wheels and tires)
3) Also considering a new set of Apex ARC-8s for the winter set...
Front - 18x9ET42
Rear - 18x9ET30
Pro: visually identical to my summer set (18x9ET42 and 18x10ET25)... which I like, and it's familiar/consistent
Pro: lighter than OEM 224 wheels
Con: expensive (wheels plus $USD > CDN currency conversion, shipping, duty, etc)
Criteria priority
1) safety (no non-certified or used wheels)
2) cost
3) performance
I'm leaning toward option 3, but would love to hear from anyone in a northern latitude who has experience with the 164 wheels and/or 215 or 225 winter tires... or if I'm unnecessarily worried about welding a cracked wheel.
Also, if anyone has the OEM 164's on their M Coupe, it'd be cool to see a photo (bonus points if it includes a snow rooster tail).
      05-09-2020, 09:22 PM   #2
CTMP4me
Drives: '08 Z4MC, '71 240Z with S54
Option 4 - go local and get a set of superspeeds. I run the 18x9.5 as my street wheels and for CAD$1K with tax, they're almost nice as my forged track wheel set for 1/4 the price.
If you want a dedicated, truly beater winter wheel set, DM me, I have a set of 17"s with tires that I can't use now that I have the PFC big brakes all around
      05-10-2020, 09:57 AM   #3
3002 tii
3002 tii's Avatar
2288
Dying seems a bit dramatic. Another option is just buying used for less than $300?
Follow for latest mods
      05-11-2020, 09:53 PM   #4
flyzipper
flyzipper's Avatar
Thanks for the suggestions, but my priority is:
2) cost
3) performance
(will update the original post)
      05-19-2020, 09:42 PM   #5
CTMP4me
2) cost
3) performance
If you wanna go down the certification rabbit hole, check out Apex's comparison table that claims that neither of their direct competitor wheels are properly registered / certified. Get the Apex wheels so at least there is some resale value in them (because OEM wheels aren't in real demand unless they're Style 5 / 42).
