      11-14-2018, 11:31 AM   #1
JimBob0047
Drives: 2006 Z4MR
Style 260m On Z4m
Enjoy!
3GFX722.50
      11-18-2018, 11:23 PM   #2
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
Those look really great. Very cool.
      11-30-2018, 07:40 PM   #3
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
They look PERFECT!! This is what BMW should of slapped on as a option.
      11-30-2018, 08:41 PM   #4
JimBob0047
Drives: 2006 Z4MR
Thank you for the kind words! I feel there is a little too much going on and it hides the big brakes compared to the factory double spokes. However they are lighter, wider, better offset than factory and they are rare in the US.
kaybat125.50
      12-01-2018, 06:40 PM   #5
Z4M_Coupe
Z4M_Coupe's Avatar
201
Drives: Z4M
What setting size/offset did you go with?
      12-01-2018, 08:57 PM   #6
rockstar93
rockstar93's Avatar
Drives: E86 Z4MC; E92 M3
Does look good - wondering how the 219M in gunmetal would look against the black. I'm partial to that wheel, though they are very similar (and have the same specs).
I briefly tried them on my E86 - wheels fit nice though the tires were a bit less than ideal.
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE
E90 M3 Sedan 6MT Jerez Black/Fox Red GONE
E86 Z4M Coupe Interlagos Blue/Black
E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread
      12-01-2018, 09:06 PM   #7
JimBob0047
Drives: 2006 Z4MR
[IMG]https://www.zpost.com/forums/attachm...8;d=1527530002[/IMG]
Here ya go! You were very helpful in knowing wether these offsets would fit the Z4M 😁
I stepped down to 235/40 and 265/35
      12-01-2018, 09:08 PM   #8
JimBob0047
Drives: 2006 Z4MR
Factory M wheels
      09-02-2019, 09:22 AM   #9
Blckoly
Blckoly's Avatar
Thailand
139
Drives: Z4M Coupe
Originally Posted by JimBob0047 View Post
Enjoy!
hi JimBob0047
what tire size you put on those nice 260M rims?
are they stock sizes? F/R?
in the front, does it rub against inner wall ?
in the rear, does it hit the wheel arch edge when driving over a bump?
sorry for many question, i really would like to change mine to this 260M after seeing these pics on internet
      09-02-2019, 11:56 AM   #10
JimBob0047
Drives: 2006 Z4MR
Enjoy!
hi JimBob0047
235/40 F & 265/35 R, absolutely no rubbing and I'm lowered on Bilstein PSS10 coil-overs.
Those rims looks great on that bronze coupe!
Here is an updated picture lowered on the coil overs
      09-02-2019, 04:14 PM   #11
wrk.eat.drive.rpt
Drives: 2016 340i, 08 e92 m3
I think those may be the 219M on the bronze car.
      09-02-2019, 07:25 PM   #12
JimBob0047
Drives: 2006 Z4MR
Negative. Spokes are thinner and face is larger. Definitely 260M.
      09-06-2019, 10:18 AM   #13
Blckoly
Blckoly's Avatar
Thailand
139
Drives: Z4M Coupe
Enjoy!
hi JimBob0047
Wow very nice!!
Thanks much
Will change mine soon then
      10-04-2019, 09:31 AM   #14
Audidude
Drives: BMW Z4 M Coupe
Just fitted set of these to my Z4M Coupe. Had them refinished and fitted OEM sizes Michelin Pilot Super Sport tyres - PS4S not available in the sizes.
(note: all same car, plate changed today between shots!)
      10-06-2019, 12:19 PM   #15
JimBob0047
Drives: 2006 Z4MR
[IMG]https://www.zpost.com/forums/picture...ictureid=71772[/IMG]
[IMG]https://www.zpost.com/forums/picture...ictureid=71766[/IMG]
[IMG]https://www.zpost.com/forums/picture...ictureid=71769[/IMG]
[IMG]https://www.zpost.com/forums/picture...ictureid=71768[/IMG]
[IMG]https://www.zpost.com/forums/picture...ictureid=71767[/IMG]
How it should have come from the factory! ❤️
What size tires did you go with?
      10-08-2019, 11:01 PM   #16
Audidude
I knew that with the different wheel offsets (42/30 going to 29/23) and 8.5inch fronts and 9.5inch rears, the outside edges of the tires would be closer to the fender - going to wider tyres would bring them even closer. I'm not convinced that there's a major advantage in increasing tire width by 1-2cm, possibly minor in the dry and almost certainly a reduction in grip in the wet. I know some like the fatter look of wider tyres, but that holds no appeal to me - the car looks great on stock width tyres.
So I went with 225/45-18 fronts, and 255/40 rears - OEM size. The tyres don't look even slightly stretched onto the half inch wider rims. The car looks great on this combo
Turns out the tires on the 2nd hand rims I bought were run flats (Bridgestone 225/40 RE050A fronts, and 255/45 S001 rears) which I didn't realise initially - the Michelin Pilot Super Sports ride far better and are much quieter as you'd expect compared not only to Bridgestones, but run flat ones to boot!!!
Now I'm wondering about switching in some Bilstein B6 shocks all around (car's done 32,000miles, and there's a creak from R rear shock)....
      10-17-2019, 10:52 AM   #17
JimBob0047
Drives: 2006 Z4MR
It more about keeping the rolling diameter as close to factory as possible so you don't change chassis and electronic(like speedometer) dynamics.
Also I would highly recommend the PSS10, I've ran a few different cars with a few different suspension setups and unless you are a track rat the PSS10 is the way to go.
      12-21-2019, 10:55 PM   #18
Polarbert
English Member
25
Drives: 2006 Z4M Roadster
Those wheels look stunning on the car. Seems like such a great combination.
      12-22-2019, 06:00 AM   #19
JimBob0047
Drives: 2006 Z4MR
Thank you!
