07-17-2011, 12:51 PM | #23 |
Rep 30
07-18-2011, 04:09 AM | #25 |
Rep 5,329
tom... any updates?? broken complete yet?
why why why have you not checked boost on this thing?? you could be running 5psi and not know??? p.s the ess clamps are rubbish and are notorious for coming loose...... a boost check needs to be done weekly if you havent got a boost gauge.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 07-18-2011 at 07:57 AM.. |
07-18-2011, 03:38 PM | #26 |
instagram 997turbotom
279
Rep 7,377
I'm putting on a bigger silicone coupler in an hour, I'll get the boost checked when I dyno it, hopefully sometime next week.
07-18-2011, 04:18 PM | #28 |
Rep 5,329
complete alpha n tune using intake temp sensor under your intake mani ;-)
07-18-2011, 05:05 PM | #29 |
Rep 476
How well does this compensate for altitude changes? Alpha-N can use any number of sensors, but I'm not totally sure all it's equipped with. My daily commute involves 2,000ft of altitude changes (at least three good "ear pops" :-P), so I've been curious for a while.
07-18-2011, 07:23 PM | #30 |
40
Rep 1,481
Use T-bolt clamps from Ebay rather than standard hose clamps.
All my boosted cars blew hoses until I installed the T-bolt versions. EXAMPLE >>http://cgi.ebay.com/ebaymotors/intak...Q5fAccessories |
07-19-2011, 11:54 AM | #31 |
279
Rep 7,377
I ordered this piece to solve my only issue. The car runs fine without it, but I'm obviously getting little to no boost right now.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT Should be easy, breazy, beautiful after that
07-19-2011, 01:08 PM | #32 | |
Rep 5,329
FFS i cant wait for one of you guys to give me your impressions on this thing :-)
07-19-2011, 01:10 PM | #33 |
279
Rep 7,377
Roman told my shop that that piece is 2.5" to 3". So we picked one up locally, but had to return it. Obviously the wrong size as it was way too tight to fit over the black intercooler pipe. *sigh
Right now my car has a half open pipe at the airbox, and sounds like a gattling gun at full throttle. hahahahaha. i don't mind, I just don't like the idea of unfiltered air getting in, so I'm not driving it much The ebay piece I found also has walls that are about 2x as thick as the ess piece
07-19-2011, 01:12 PM | #34 |
279
Rep 7,377
I had no boost leaks on my first day out, so I did get a short impression of the potential. It was fantastic. Thats why I'm not stressing over this situation
07-19-2011, 02:10 PM | #35 | |
Rep 5,329
07-19-2011, 02:13 PM | #36 | |
Rep 5,329
definatly see what your saying about the unfiltered air, defo not good on the s/c or turbo setup, those blades are fragile.....
07-19-2011, 04:00 PM | #37 |
279
Rep 7,377
No- the air coming into the blower is filtered, just have a gap on the airbox area going to the engine
I just called the store to upgrade my shipping, to make sure I get it by Friday
07-19-2011, 04:14 PM | #38 |
Rep 5,329
arhhh my bad excuse me.
07-19-2011, 04:31 PM | #39 |
279
Rep 7,377
I hope we ordered the correct diameter piece and that it fits, because Roman@ess said its a 2.5" to 3" reducer, which we tried on because there was one available, and it was too tight to fit
07-20-2011, 04:14 AM | #40 |
Rep 5,329
3" to 2.5 should work no probs??????
07-20-2011, 09:25 AM | #41 |
279
Rep 7,377
Thats what I tried. Maybe because the walls were much thicker (5 layers vs 2), it would not fit because it is less flexible. I also lined up the ESS elbow to the other 2.5" pipe, and there was definitely a difference in diameter, I'm betting its .25". Maybe because it stretched?
07-20-2011, 09:37 AM | #42 |
Rep 5,329
yeah thats makes sense and ess's pipe is alot more plyable, you can really stretch it....
your new one just put something really thick in their to stretch the silicone :-)
07-20-2011, 09:40 AM | #43 |
279
Rep 7,377
Shouldn't be a need to stretch the new one, since it'll be 2.75" at the intercooler pipe. Sounds like ESS in Norway will re-imburse me for the new intake elbow I'm buying (hopefully?), and depending on fitment, may use something similar for all future kits as per our recommendation
07-21-2011, 02:24 AM | #44 |
Rep 5,329
im wondering if your new silicon piece has come in yet??
