      03-20-2012, 06:40 PM   #1
ocsdgirl
Drives: Z4
Question Z4 question
I have 17 inch wheels/tires, can I put 18 inch wheels/tires instead? That would fit right?
      03-20-2012, 06:43 PM   #2
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
The sport package came with 18" wheels stock
      03-21-2012, 02:18 PM   #3
DerekSelmanRacing
DerekSelmanRacing's Avatar
Drives: 05 Z4 3.0 SMG, 01 530
Yes (see above), but why? Unless you plan to track the car, it will ride better and there will be less tendency for wheel/tire damage with the 17's.
      03-21-2012, 04:26 PM   #4
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Also depends on the tire profile. the second number in the tire specs.
For example: 275/45/18. 45 is the height of the tire based on the percentage of the 275.
So if you put 18s on, you need to adjust the tire sizes so the entire wheel and tire isn't much larger or smaller than your 17s wheel and tire. Did I make sense?
      03-21-2012, 04:39 PM   #5
Hawkeye
Hawkeye's Avatar
No_Country
2070
Some people enjoy the cosmetics of an 18" wheel over a 17" wheel. Myself included.
I believe even 19" fit on the Z4 although there may be slight rubbing issues with 19" at full turn.
      03-21-2012, 05:12 PM   #6
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
this thread has everything you need.
http://www.zpost.com/forums/showthread.php?t=398990
and welcome to zpost!
_
      03-22-2012, 05:02 AM   #7
DataStream18
Drives: 2003 ESS TS1 Z4
I have stock 18's and I dropped my Z on its belly basically, I only rub with a big bump and can turn from lock to lock (all the way left, all the way right) with no rubbing.
Love is like a fart; if you have to force it, it's probably shit.
