      03-27-2014, 01:39 PM   #1
just2talented
just2talented's Avatar
Drives: Alpine ///M roadster
Short Shift Kit Causing a Transmission to Fail?
Im currently working with a company that is going to rebuild my transmission. They claim that using a short shift kit can cause transmission failure. Im looking to purchase the Auto Solutions short shift kit after the transmission is repaired. Has anybody heard of this happening? Anybody unhappy with auto solutions?
      03-27-2014, 02:05 PM   #2
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
I know many have SSK, but never heard it caused transmission failure.
      03-27-2014, 02:37 PM   #3
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
Autosolutions SSK and RE Tranny mounts FTW!!
Even better would be those with Vibra-Technics motor mounts. Shifting nirvana!!
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
      03-27-2014, 02:49 PM   #4
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
I have the RE tranny mounts and the Vibra-Technics "Fast Road" mounts and it's awesome. I use an OEM BMW Performance shift knob, so the throw is very low and I doubt I'll do the SSK unless I find a stupid deal on one, at which point I'll probably change to a different shift knob.
Go forth with confidence; all reports are that the AS SSK is the best on the market, period.
      03-27-2014, 05:49 PM   #5
just2talented
Do u still get the 2nd gear grind with that set up?
      03-27-2014, 06:40 PM   #6
Shipkiller
Shipkiller's Avatar
Drives: Me
Who is rebuilding your transmission? This is interesting...
      03-27-2014, 06:42 PM   #7
just2talented
Diffs online
      03-27-2014, 10:47 PM   #8
msh441
msh441's Avatar
17
Drives: 2007 BMW Z4 M Coupe
The only thing I've heard along those lines was from an interview with Steve Dinan. Basically from what I recall it went something like this:
The reason for the lack of clutch stop, long throw shifter and CDV combo was to slow down the shifting and compensate for crappy drivers.
Removing the CDV, adding a clutch bump stop and going with a short shift kit makes shifting more responsive to the driver's actual inputs.
In this respect, there's more potential (if your ham fisted) to burn up a clutch quicker... but to toast an actual get box? No-way.
      03-28-2014, 09:19 AM   #9
nekky
Wagon life
nekky's Avatar
Very rarely. When cold, obviously. But this helped a TON.
      03-28-2014, 09:21 AM   #10
bignosejim
bignosejim's Avatar
Not when going from 1st to 2nd, but I have also trained myself to push the shifter to the left. With the VT and RE mounts there is a lot less movement between the engine/transmission and the the shift linkage when on the throttle. I think this helps cut down on 2nd gear grinds the most.
Also the VT mounts make the car more responsive to throttle changes since the motor is held in place better.
I haven't had my car on the track, so I cannot comment on 3rd to 2nd gear denials.
      03-28-2014, 12:15 PM   #11
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
3rd to 2nd isn't just a Z4M issue. My 95 E36 does the same thing. It was like running in someone you don't want to see but know very well last weekend at the track with the E36. (I pretty much use 3-4 only, but needed 2nd due to someone being in the wrong run group and slowing too much at one turn--needed but couldn't get--hello-- at least I wasn't too surprised.)
Does it in the street too when hot.
I'm going to see if an x-brace and new transmission mounts cure it.
      03-28-2014, 12:17 PM   #12
just2talented
Did somebody make an X brace finally?
      03-28-2014, 01:06 PM   #13
nekky
Wagon life
nekky's Avatar
I haven't gotten a single second 2nd gear denial since I've done the two sets of mounts, fwiw. You can actually feel that difference quite a bit in my opinion. I'll report back after more seat time. New Throttle Pedal (3rd TPS) going in at the end of the month, and hopefully snow will be gone. You can rest assured I'll let the car stretch her legs soon.
      03-28-2014, 02:18 PM   #14
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
We need to fix that. Lots of good tracks around us!
      03-28-2014, 05:23 PM   #15
Finnegan
Finnegan's Avatar
E36? Yes. Z4? Not that I'm aware of. Doesn't need it though given how stiff the chassis is anyway.
