07-04-2017, 08:52 PM | #89 |
no turbo, no auto, no iDrive, no kidding
105
Rep 425
Vettel did get a penalty, which cost him the win or even a podium. I think the actual contact was unintentional, just as much as was Hamilton's slowing.
07-05-2017, 02:33 PM | #92 | |
Rep 3,336
Drives: X5 & E90 WTCC Widebody Racecar
Remember, the pace car was running 20 seconds a lap slower than it should have been. Hamilton was continuously on the radio about the slow pace speed leading to tire temp issues all race. That said, imagine hitting 200mph and then having to brake like your life depended on it coming into turn 1 with COLD tires (if you haven't tried going 100% through a turn with cold tires, you probably haven't had a code brown moment! - let alone after braking from 200mph!?). That said, it would only make sense to get as much heat in your tires prior to entering that long straight. TADA... this was exactly where this "incident" took place at turn 15 leading to that last zone to improve tire temps. I see zero mishaps with Hamilton's behavior. That said, I believe that Vettel did not intentionally run into Hamilton. I think he pulled along side of him, raised his hand to show some "emotion" and while looking that way; he unintentionally steered into him (ever lean down to grab something in the car and accidentally swerve?). It should never have happened in the first place; and he's rightly at fault. But I don't think he intentionally made contact with Hamilton. Regardless, my hat goes off to Bottas. One of the best drives I've ever seen. Down a lap and in last place to 2nd(!) in the last couple hundred feet. Incredible drive. And I'm calling it now that RAI is out and Verstappen may very well be wearing red next year |
07-05-2017, 05:54 PM | #93 | |
Rep 1,968
Over the radio: To Hamilton: "OK Lewis that was pretty close on that last restart" Hamilton: "Close to what?" To Hamilton: "The Safety Car, and Safety Car Line One" Hamilton: "Trust me, it wasn’t" Article 39.8 of the Sporting Regulations states: “No driver may overtake another car on the track, including the Safety Car, until he passes the first Safety Car Line for the first time when the Safety Car is returning to the pits.” They had lots of problems on the Baku restarts last year in GP2 for the *exact* same reason, causing crashes (and resulting in race bans), with drivers calling for a change in restarts at Baku: https://www.motorsport.com/fia-f2/ne...ku-789878/?s=1 Last edited by jkoral; 07-05-2017 at 10:26 PM.. |
07-05-2017, 09:48 PM | #94 | |
Driver
2692
Rep 2,714
07-06-2017, 01:46 AM | #95 |
Rep 1,287
Lol Vettel accidentally tilted his wheel into Ham? Must be so hard for formula 1 champions to drive with one hand while using the other hand for another purpose. You know, like trying to fix a headrest while going 200mph down the straight then braking hard and still holding the wheel straight.
Real "accidental swerve". |
