      10-04-2011, 06:14 PM   #1
suprtran
suprtran's Avatar
111
Drives: BMWs
Question Problems with Flat Tire Light
I have an 06 E85 M Roadster. I can't seem to get the flat tire indicator light in the dash to turn off. I don't believe I have TPMS because the valve stems on my stock wheels are regular black. I know how to turn off the flat tire indicator on my E46 M3, but can't do it on the Roadster for the life of me.
Any suggestions?
      10-04-2011, 07:38 PM   #2
wdupdog
wdupdog's Avatar
Drives: Z4
My manual says start engine, press tps button on console till yellow light comes on, then drive off. Light will reset and go out in a very short time.
      10-04-2011, 10:41 PM   #3
suprtran
suprtran's Avatar
111
Drives: BMWs
Since yours is an 08, I'm going to assume you have TPMS. So, the reset procedure might be different.
      10-04-2011, 11:23 PM   #4
chickdr
Drives: 2006 M Roadster
I have an 06 and the above worked for me when I got a nail in a tire and dropped the pressure.
      10-05-2011, 06:29 AM   #5
wdupdog
wdupdog's Avatar
Drives: Z4
[QUOTE
Since yours is an 08, I'm going to assume you have TPMS. So, the reset procedure might be different.[/QUOTE]
Yes you are correct on ABS vs TPMS monitoring. 06-earlier ABS, 07-on, TPMS. But I believe the reset procedure is the same.
      10-05-2011, 08:42 AM   #6
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
      10-05-2011, 09:07 AM   #7
wdupdog
wdupdog's Avatar
Drives: Z4
Couldn't get the link to load. What does it say?
