      10-03-2011, 12:13 PM   #1
jnkhan82
jnkhan82's Avatar
Drives: 03 Z4 2.5i
Car Battery
Hey,
I found out my battery is going bad, tends to die if I don't start my car every 3-4 days. I was wondering if there is a brand anyone would recommend?
Also is the battery swap easy on the z's? I'm not very handy when it comes to car issues...
Thanks in advance.
J
      10-03-2011, 12:29 PM   #2
TriAdX
Drives: 1968 Mustang - 07 Z4MC
lmao.. ur sig "bug" just got me.. I tried to "squish" it.. but to no avail!
2007 Z4M Coupe - 2010 Ducati 848 - 1968 Mustang 302
      10-04-2011, 08:18 AM   #3
GeorgeT
GeorgeT's Avatar
Drives: 2007 750i; 2003 Z4 3.0
J
Go to your local parts store (Advance Auto, Autozone, O'Reillys etc.) and have them replace it. It's really pretty simple. They are pricey, in the $150 range, depending on capacity. Interstate, Delco and most "branded" batteries are good.
      10-04-2011, 09:43 AM   #4
gferil
gferil's Avatar
30
Drives: 06 Z4MC
^I agree with above if you aren't comfortable doing it on your own. Sears usually does a good job too. Just makes sure that whatever battery you have meets or exceeds the specs of the OEM battery, don't let them put a battery in that doesn't have as much cold cranking amps, etc.
      10-04-2011, 03:20 PM   #5
jnkhan82
jnkhan82's Avatar
Drives: 03 Z4 2.5i
Thanks guys! going this week to swap it.
      10-04-2011, 04:04 PM   #6
chickdr
Drives: 2006 M Roadster
One other comment. My battery seems to be dying off as well. I had looked at O'Reilly previously and noticed they carried an AGM battery for $155(part #48-AGM) which is cheaper than the OEM battery and appears to be identical in every way. Today I noticed they also carry a non-AGM version which runs $105(part #48-72). Same dimensions as the AGM, same 72mth 2yr replacement warranty. The only difference is CCA are a bit lower at 700 vs 760 for the AGM version. Seems like a great deal to me.
      10-04-2011, 06:37 PM   #7
pelerojo
Drives: '06 Z4M
I went with the AGM and the higher CCA and it makes a difference at least with the S54. It spins over much easier. Perfect fit. Easy Install, but not cheap.
      10-04-2011, 06:58 PM   #8
chickdr
As my store did not have the AGM type in stock I went with the standard battery. Seems to work fine on my S54. It is also identical to the OEM battery for anyone who wants to know. I bet it came from the same factory. We will see about cooler temps, but I can't imagine 60 less CCA could make too much difference as the rest of the specs are the same. I certainly like the 33% lower price. Install was plug and play, but the cover was a pain to get back in place.
      10-04-2011, 10:30 PM   #9
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Just pro-actively replaced my battery due to my Z4M's production date of Nov 06....and a replacement date of July 2011 (4.5 yrs old....that's enough).
My BMW dealer replaced my battery during schedule inspection.
Hey,
Thanks in advance.
J
Racerbruce
      10-05-2011, 03:20 AM   #10
imom
Drives: Subaru BRZ ....... Z4MR (SOLD)
chickdr - when you had the battery replaced...did you have to attach to another battery or battery tender to keep the computer settings alive? I heard some German cars require this...wasn't sure if the Z4s required this, just read some post about battery failure and going into limp mode afterwards.
      10-05-2011, 08:19 AM   #11
chickdr
I think the E85 Z4 is one of the last BMW's to allow a true DIY battery replacement. I took my battery out, and brought it to the parts store to get the core value then brought the new battery back and installed it. All I had to do was reset the clock. It fired right up.
      10-06-2011, 10:02 AM   #12
Evan70
Drives: 2010 335i
Just replaced mine about a month ago with the AGM from Oreillys. Did the swap myself, very easy. Old battery died very suddenly, literally went from working fine to not holding a charge at all in 8 hours. So if you have a 2006 model year, you might really want to think of proactively swapping it if you don't have a second vehicle.
Evan
2010 335i
2013 Corvette Grand Sport
      10-06-2011, 11:21 AM   #13
CJW2OO4
CJW2OO4's Avatar
this is an older thread from e46fanatics that discusses replacement batteries. It might be of some help to people looking to replace their unit.
http://forum.e46fanatics.com/showthr...756&highlight=
      10-06-2011, 11:21 AM   #14
chickdr
Funny, this is exactly my story. I drove the car one night and all was well then it was completely flat the next day. I put it on the charger and it did start after a few hours, but the battery did not top off as usual after 24+ hrs on the charger. I figured why not go ahead and replace it...
      10-06-2011, 12:58 PM   #15
Silververtu
Silververtu's Avatar
231
Drives: 2015 X5 50i M Sport
Feels like i should get mine replaced soon
2019 Cayenne Turbo
Gone but not forgotten:
2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport
      10-06-2011, 02:46 PM   #16
gferil
gferil's Avatar
30
Drives: 06 Z4MC
When I replaced my battery, I didn't hook it up to a tender and with the exception of the auto up on the windows not working right away (they started working after a day or so), everything else was fine.
However, last week when my battery died while the car was parked at the airport (and I was only gone 4 days), the car went into limp mode for the first 20 minutes. So as long as you are doing a swap the same day you should be good...I think.
      10-06-2011, 07:08 PM   #17
santov
santov's Avatar
64
Drives: 2007 Z4 3.0si White over Beige
Don't be afraid to swap your own batteries. There's no codes or errors that need to be reset. You will have to reset the clock and MAYBE the windows (search around for the procedure).
I've topped my battery off with a tender overnight about once a month (when I remember). It def starts faster when topped off.
      10-07-2011, 01:10 AM   #18
chickdr
That thread discusses #94 size batteries which are not the same as our 48 batteries. What I found interesting is the posts about 11yr OEM battery life! Amazing- twice as long as most M owners are getting.
      10-07-2011, 10:07 AM   #19
gferil
gferil's Avatar
30
Drives: 06 Z4MC
Yeah...the battery in my E46 lasted 10 years...but then again in those 10 years it was driven 140K miles, so regular use and recharge from the alternator definitely helped...my coupe has only seen 39K miles in the past 6 years and I just replaced the battery a few months ago.
