      10-08-2013, 10:47 AM   #1
3002 tii
3002 tii's Avatar
2272
Why Does Optimal Camber Vary for R-Comps?
So after 30 or so track days I think I'm finally ready to move up to R-comps. In those 30 days I started with Hankook V12's, then Star Spec Z1 and lastly RS3's. I was actually thinking of going back to Star Specs (Z2) but after 'talking' to some folks on bf.c, I think R888's might be a good first R-comp tire. With that said, I've been reading up on different R-comps and what their optimal temp, air pressure and camber settings are.
My question is, why do different tires have different optimal camber settings? For exmple, I was ready to dial in more camber on my car (currently running -2.8*) but read the R888's work best between -2.5 and 3.0* so I'm thinking maybe I should keep my settings as is.
Follow for latest mods
      10-08-2013, 11:59 AM   #2
Kgolf31
Kgolf31's Avatar
459
Drives: 2007 Z4MC, 2012 128i
Simple for now, sidewall construction varies from tire to tire
      10-08-2013, 02:51 PM   #3
seank
enthusiast
seank's Avatar
48
WHS. Camber settings that you read about are related to the tire sidewall. That being said, there are other factors that affect it:
-car weight, as well as where the weight is. On top makes the car roll more.
-suspension (most related to spring rates or sway bars)
-how talented of a driver you are. The fast guys get more grip out of the same tire.
-Etc.
At the end of the day, use the info as a starting point and make changes from there.
      10-09-2013, 01:02 PM   #4
jmillet
jmillet's Avatar
63
I run my R888s at 3.5 negative front camber with good results. The challenge with the R888 is hot tire pressure. I start them out cold at 36 psi front and 34 psi rear with the goal of achieving hot pressures of 45 psi front and 43 psi rear.
My experience is that with lower hot pressures the R888 tends to scrub off the outside edge of the tread rather than wearing evenly. Tire adhesion does not seem to be impacted by tire pressure because the R888 has a very stiff sidewall.
YMMV
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      10-14-2013, 10:23 PM   #5
sipman
Drives: 2007 Z4MC
How are you getting the R comps to the track? Driving them or build a trailer?
You doing the PCA last weekend of Nov at NJMP?
      10-14-2013, 10:28 PM   #6
3002 tii
3002 tii's Avatar
2272
I'll be there 11/2-3 with Schattenbaum.
Driving to/from track, will follow forecast and if any chance of rain I'll stick to star specs. But I don't plan on running my r-comps till 2014.
      10-14-2013, 10:30 PM   #7
sipman
Drives: 2007 Z4MC
Cool. I'll be there too. I'll say hi.
