03-20-2011, 12:13 AM | #1 |
Rep 255
SUCCESS!! Re-Located and Extended rear o2 sensors!
Hey Guys,
Spent the weekend getting my exhaust all figured out! I now have the following setup Euro Headers Factory Section 1 with relocated EGT and rear o2 sensors Factory X-Pipe (Will be changing soon) Rogue El Diablo Mufflers I put on about 125 miles this afternoon/evening with the car (through all RPM and load ranges) and have yet to throw anything close to a code. I ended up cutting off the welds along the sides of the heat shield covering the cats. Underneath it was very easy to figure out where and what to do. You can clearly see the spots where the factory o2 sensors were placed. The manufacturer of the bungs had the perfect "J" Bungs on backorder for a couple months, so I was able to weld two 45degree bungs together to create my 90degree bend. (I did have to offset one bung a little bit to get the o2 to fit all the way in without contacting) Once I got the o2's welded in place, I notched, cut and bent the heat shield around the o2 sensors and welded the entire cover back on. It looked almost factory! So, Half way through the process my iPhone died and I didn't have another camera with me So I didn't get pictures of the rest of the process. Sorry Guys!!! Like I said.. no codes as of yet!!! and I am in love with the sound!!!
03-20-2011, 12:52 AM | #2 |
Rep 1,739
Drives: 2008 Z4MC
Nice! Good to see everything worked out for ya
03-20-2011, 11:06 AM | #3 |
International Bar Hopper
25
Rep 350
Drives: 2006 Imola Red Z4 M Roadster
Congrats....very nice work
2006 Imola Red Z4 M, ESS VT2-500 Supercharged, SS V2 step headers, AEM water/meth, Nitto NT555R Drag Radials, ESS VT3 coming
03-20-2011, 07:37 PM | #4 |
Rep 632
Rated M
Nice work - too bad we don't have pics though.... Can you explain how you handled the wiring? Sources for part if you used different connectors? thanks
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
03-20-2011, 08:46 PM | #5 |
Rep 255
Hey guys. My local napa carries a wire heat shield identical to the sleeve that covers the oem o2s.
I just cut and soldered in 16ga wire for the o2s and 20ga (just standard primary) for the egt sensor. I staggered the cuts so all the heatshrinked connections wouldn't bunch up in one area under the sleeve. I extended the rear o2's by 60 inches and the egt by 48". This left me with an almost perfect amount of extension. I am going to be picking up an aftermarket x-pipe in the near future. I'll take the section one down at this time and get pics. 425 miles with no codes. Car has now adapted and I am insanely impressed with the performance!!
03-20-2011, 10:41 PM | #6 |
25
Rep 350
03-21-2011, 06:49 PM | #8 | |
Rep 632
03-22-2011, 08:49 AM | #9 | |
Rep 255
I never got a baseline dyno so it will be hard to know the true gains I got from this, But I am going to get a dyno session done here once the weather gets nicer.
03-22-2011, 08:56 AM | #10 | |
Rep 255
I picked up another set of rear-o2 sensors for really cheap. This way I can revert back to stock and sell the extended o2's to another lucky member here.
03-22-2011, 09:22 AM | #11 | |
Rep 1,110
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 * '14 Jeep Grand Cherokee Overland Hemi... No more snow for the M! |
03-22-2011, 06:01 PM | #13 | |
Rep 632
03-23-2011, 07:06 AM | #14 |
Rep 2,120
I was under the impression from the M3 guys who have fitted euro cats that you do not need to extend the o2 wires,
according to them there is anough slack winded up under the valve coverto reach the reloacted o2's and EGT, I'll be installing mine end of the month when my headers get here and I wasn't planning on extending anything,
Imola Red Roadster |
03-23-2011, 07:13 AM | #15 |
Rep 11,667
^ I heard the same thing.
03-23-2011, 07:32 AM | #16 | |
Rep 11,667
Nice work on this!!! I would have loved to see more pics too. I really like your idea of splitting the heat shield & reworking it instead of chopping it up. Great idea!!! ----- I'd also like to hear your impressions on how the sound has changed with the headers & elimination of the cats.
03-23-2011, 08:41 AM | #17 | |
Rep 255
My first thought as well. And there is no way you would be able to do this. I extended by 5 feet and only had about 6-8 inches to spare if you stretched it tight, but I followed the stock routing path under the valve cover cover (lol). You could potentially pull the wires and the connectors out and shave a couple feet off the extension, but then you would have unprotected plugs down by the transmission. (not to mention the plugs are not weathertight)
03-23-2011, 08:44 AM | #18 | |
Rep 255
[QUOTE=inTgr8r;9192997]
03-23-2011, 09:06 AM | #19 |
Rep 2,120
Thats so weird,
Look at page 3 of this http://m3forum.net/m3forum/showthread.php?t=151391 I can't see ours being any different?
03-23-2011, 09:21 AM | #20 | |
Rep 255
That's my first time seeing that thread and I can see that being feasible. My only issue with it again is not having weather tight connectors out in the open, rather than tucked up under the valve cover cover. I ran my o2 extensions in the exact same path as oem and shouldn't have to worry about any issues going forward. Total cost of the extension was about 50 bucks.
05-04-2011, 02:19 AM | #22 | |
Rep 987
As seen in Mikymu's M3forum thread you have to free up the wires BEFORE they enter the valve cover cover to get the needed extra length. From there you just take your time routing everything high and tight. I will definitely be doing this mod with my new2me Z4MC soon. I'll take pics if nobody has done so by then. |
