      05-04-2011, 01:58 PM   #45
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Originally Posted by Iwantacookie! View Post
I would like to see both sets of dyno results with the same octane and ambient temperature conditions on one side of the argument and then the feel/acceleration on the other, to have a good comparison between the VT-1 AND vt-2.
How many VT-2 kits are on the road out there compared to VT-1?
And, I agree if you have the additional money and are near a ESS certified shop to do the VT-2 version, it makes more since to proceed dirrectly to go...but is the additional expense under the same circumstances that much different? I mean, isn't the only modification of the VT-2 is removing the front end and installing the cooler and duct work? I was surpised that the power gain off the dyno from the VT-1 add was less than I had expected, so if the VT-2 was available I would have added it.
I have the VT-1 and think the difference between and OEM set up and VT-1 is worth the money. The pull in 1st and 2nd is incredible. It will load up in low speed turns on track day because of the power curve...but I can control that by keeping my rpm's up and getting a smoother shifter or shift point. I can now maintain speed with a V06's on the straightaways where as before I could not. I have had an issue with some boost leakage which has hampered preformance...and I am still trouble shooting this point.
JMO
Z06's?
Pretty interesting that 2 more people came out of the woodwork that have an ESS kit, glad to see more opinions
