      07-10-2013, 01:43 AM   #1
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
Do I have enough Brake/Clutch Fluid?
about to tackle flushing/bleeding my brakes and clutch fluid, is 1 liter enough?
      07-10-2013, 11:08 AM   #2
Drives: M2 Comp
I usually have 3 500ml bottles on hand.
      07-10-2013, 12:33 PM   #3
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
When I did mine, I bought 2 1L cans, but only used one. Always good to have more than enough, especially for brakes.
      07-10-2013, 12:47 PM   #4
The HACK
The HACK's Avatar
1817
So are you flushing or bleeding? Because it takes about 1.2L to completely flush. But a bleed can be done with less than 1L.
      07-10-2013, 02:31 PM   #5
GuidoK
#buildnotbought
GuidoK's Avatar
10473
Drives: Z4 3.0i ESS TS2+
Complete flush takes less than 1L, but you have to know when the old fluid is drained/flushed so you don't flush extra fluid in vain.
I've weighed my 1L brake fluid tin can that I have left from my last flush (that is with a 6 piston front bbk, 2 piston rear bbk, which holds more fluid than the stock calipers) and the tin can still weighs about 400gr/0,9Lb (thats can+fluid). That's after a flush incl the rotation of the abs pump (you can do that for exemple with BMW DIS software)
So if you can determine the point where the brakes are bled/flushed just right (eg. by using a different color brake fluid) the 1L should be enough. If I estimate there is still about 200ml or so in the can.
Still it doesn't hurt to have an extra bottle standing by. If you buy your fluids locally most shops don't mind if you return an unopened bottle, especially when you ask them in advance.
      07-10-2013, 09:21 PM   #6
i2ichal2dZ4M
full flush of brakes and clutch, thanks guy! doesnt hurt to have extra!
      07-24-2013, 02:08 AM   #7
i2ichal2dZ4M
Update for those that were also wondering. I was able to do a full flush of clutch and brake lines with a bit under 1 liter. so 1 can is enough if none is wasted. I swtched to ATE Blue so i knew when exactly new fluid was in the lines and when to stop flushing. Not much was wasted.
