      10-18-2019, 10:12 AM   #1
Spec-Al
Drives: bmw
E86 non M - Style 203 square
Thinking about using a square setup of the rear factory Style 203 wheels. Has anyone run this setup before? Going from a 8.0 +47 to a 8.5 +50 doesn't seem like a big deal, but would like to not rub at all. Stock suspension (M sport), ideally 235/40 all round. Thanks!
      10-20-2019, 07:27 AM   #2
3002 tii
3002 tii's Avatar
2288
Without camber 235 may run because of the increased height. It’s been a while but I think mine rubbed the outer edge of the liner where the bumper and fender meet.
Follow for latest mods
      10-21-2019, 06:13 AM   #3
Spec-Al
Drives: bmw
Thanks for the info, surprising with only a 1" change in overall circumference
      10-21-2019, 11:20 AM   #4
3002 tii
3002 tii's Avatar
2288
Not even it’s only 1/3” taller but with wide enough rubber it’ll rub in the right spot. But if you pull the camber pins that should be enough to pull it away from the liner.
