      04-07-2008, 07:20 AM   #1
iamwiz82
Drives: 2010 335d / 2012 MCS JCW
Z4 M Wheels - Performance Aspect
I'm looking to replace my stock wheels and tires as I can no longer stand the Conti's on there, and if I am replacing tires I may as well do everything . I've been debating on which way to approach the situation and I have a few questions that have probably been answered before, but I am failing at the search.
First, I would prefer to go with a non-staggered setup, so I assume I will need spacers in the back, correct?
I live in Michigan where it's now pothole season, and I am concerned about 19" wheels surviving very long. On the other hand, I like the look of very few wheels, and the M6 replicas certainly pique my fancy, but an 18" rep. looks to only come in 8" width, which means a fairly narrow tire. Is this advisable?
Assuming 8" rims in back are too narrow, would it be crazy to run an 18"x8" wheel up front and a 19"x8.5" in back? Or should I just give up and run 19x8.5 all the way around?
      04-07-2008, 09:21 AM   #2
Burt Reynolds
Burt Reynolds's Avatar
53
Drives: 2007 M Coupe
Why do you not want a staggered setup? Just curious.
Regarding wheel size, I am having same dilemma with 18s vs 19s b/c of potholes here in Chicago.
      04-07-2008, 10:02 AM   #3
Reach
gone baby gone
382
Drives: 2016 F80
A standard (non-staggered) setup should handle more neutrally, allowing oversteer on turn-in as the rear wheels can slip easier. It would be better for hard tracking and performance driving.
I don't think 8" wide rims are "small" by any means. Just because some people go super wide doesn't mean thats the optimal setup.
I did find some 18x8.5 M6 reps by a major knockoff company (not Miro), but if I were you I'd stick to reps only by known good companies (like Miro and Velocity Motoring, who doesn't offer an m6 style)
      04-07-2008, 10:10 AM   #4
iamwiz82
I agree that an 8" rim is not narrow, but I am also concerned about delivery of power to the ground. Is a 225/235 tire going to offer me enough traction back there, or will I leave trails of rubber at every light?
      04-07-2008, 11:12 AM   #5
Reach
gone baby gone
382
Drives: 2016 F80
235/245 should be plenty good, with a good tire! remember selection makes a big difference too.
With my current 255 pilot sports, I can't even take off the line without spinning out in the rain, but on dry pavement look out! And thats "just" in my "small" 3.0
      04-07-2008, 11:20 AM   #6
BlackSapphireZ
Drives: 22 GLE 53 Coupe
if u want to trade ur front for my rear, i'll do it
2022 GLE 53 Coupe
      04-07-2008, 11:21 AM   #7
Burt Reynolds
53
Oversteer is easy on this car (M coupe/roadster) with a staggered setup. If anything, it is a little tail happy with a staggered stock setup. I am personally going to buy some 275 rear/245 front setup wheels to improve my handling when I buy tires next.
Caveat- I am coming from a high powered AWD setup (race prepped) though so my benchmark about grip is probably in a different place.
      04-09-2008, 10:25 AM   #8
runnerx
runnerx's Avatar
Drives: 06 M roadster; 06 330i 6spd
little oversteering or understeering can be dialed out by playing with the the amount of air in your tires.
theoretically non-staggered setup should introduce more oversteering since the front would have a lot more grip. having too much grip in the front isn't always a good thing. Non-staggered setup would have this "snap oversteering" behavior, which really isn't what you want either. There is a reason 95% of sport cars have staggered setup.
I got my new F1 Asymmetrics 235/40-18 front and 265/40-18 rear, haven't mount them yet. would love to go 245/40-18 & 275/35-18 but afraid may rub.
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual
2006 BMW 330i 6spd manual - gone
https://lh5.googleusercontent.com/--bIgrh8ES_s/TxSUCvOmDUI/AAAAAAAAPh0/OOjwrRZtta0/s912/z4mcomparo.jpg
      04-09-2008, 11:00 AM   #9
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
FWIW....
I'm running 245 on 8.5" ET35 & 275 on 9.5" ET22 with no rubbing issues.
      04-10-2008, 05:16 PM   #10
schwank
Drives: 06 z4 m coupe
it would be nice to be able to rotate tires...
      04-10-2008, 10:13 PM   #11
runnerx
runnerx's Avatar
why do you want to rotate tires?
2009 BMW X5 4.8i
      04-11-2008, 07:20 AM   #12
iamwiz82
It's tail happy when you are on the gas too much, but otherwise it's like trying to steer a train in the corners.
      04-11-2008, 07:11 PM   #13
Burt Reynolds
53
Like I said- it is tail happy Seriously, it understeers less than my 2 previous all wheel drive cars so I guess I am coming from a different reference point.
