      08-04-2010, 02:03 PM   #23
PatJags156
PatJags156's Avatar
Drives: 335i Convertible
How long did the install take?
      08-04-2010, 02:29 PM   #24
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by Caddyshk View Post
Looks like I'll be ordering a set of the Black UUC mounts - the design looks better than Rogue IMO.
Thanks inTgr8r for the install today on the SS brake lines and encouraging me to keep swapping out OE parts
My problem is the 3-2 downshift under hard braking - hope this solves it - will swap the fluid at the same time - any reco's on fluid beyond the OE Castrol?
no problem.
I'm good at helping others spend money
I love the Royal Purple Synchromax that Rocco put in for me.
      08-05-2010, 08:18 AM   #25
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
About 1 - 1 1/2 hour. I took my time and it was insanely hot in my Texas garage at 5pm. Yup I need an AC unit for the garage.
no problem.
      08-05-2010, 01:06 PM   #26
RBull
Drives: 2007 M Coupe
yes, you are. Looking for lines now.
no problem.
      08-15-2010, 06:35 PM   #27
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
Just got mine on the mail (option 2), but will take a little to instal.
      08-15-2010, 08:50 PM   #28
F360C
Drives: E86 S54
Originally Posted by Blind32 View Post
So anyone want to buy some UUC option 2 Tranny mounts half price?
How much shipped to 07871?
07 Z4 M Coupe AW/IR
      08-15-2010, 09:05 PM   #29
Shipkiller
Shipkiller's Avatar
Drives: Me
Caddy,
I put in Royal Purple SyncroMax on Saturday and have put on about a 100 miles with it in.
The shifting is MUCH better. I never had the grind issue but sometimes I would miss a up shift. Now that issue is gone.
I really do like this SyncroMax fluid.
I did a couple more mods this weekend also but that will be in another thread.
      08-15-2010, 09:58 PM   #30
Blind32
Blind32's Avatar
Drives: '07 Z4MC
I actually decided to keep them in and now I love them.
      09-05-2010, 08:20 PM   #31
dekaliber
Well, crap. Got my car on the ramps and took off the heat shield only to realize that there was no way I could access the bolts on the passenger side with my current tools. I'm guessing you used an offset box wrench or an angle-head?
How did you tighten the nuts on top? Looks like you just put your hand up there but since they're locking nuts, I have no idea how you were able to torque them down.
      09-05-2010, 08:28 PM   #32
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
I used my oem nuts. I hand tightened the top with my hands and just torqued down the bottom nuts. The top should be torqued as the bottom nuts squeeze the bushings upwards. Maybe I did it wrong, but I've had them for a couple hundred miles---no problems so far.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      09-05-2010, 09:43 PM   #33
jbh
jbh's Avatar
18
Drives: 2007 Z4M
I used a small 1/4 drive socket wrench to tighten. I was not able to get a torque wrench up there.
      09-07-2010, 10:52 PM   #34
dekaliber
Got a 13mm flex-head ratcheting combination wrench and 45° offset box wrench in the same size and got to work. The flex-head wrench made it a LOT easier -- I was able to reach the top nuts without too much trouble.
Took a shower afterwards and drove around for a few miles. The new mounts makes the shifter feel much sturdier and the car as a whole felt stronger. There is less hesitation as you're switching gears over uneven terrain. As others have said, it also changes the tone of the engine appreciably. It's louder, almost bassier, and there is noticeably more NVH, especially at higher RPMs, but not in an unpleasant way. The revs going up and down now have a distinctly tactile element that wasn't present before. I only have the black neoprene ones without the enforcer cups (option 1).
Compared to the improvements in drivability effected by the Zeckhausen CDV and the ZHP shifter, I'd say the UUC mounts are somewhere in the middle. The three combined make the transmission highly tolerable, if not pretty close to perfect.
I'm wondering if the more-than-expected NVH might be due to my over-torquing some of the fasteners. I was only able to access the two bolts that connect the brace to the body and the bottom brace-to-mount nut on the driver's side with a torque wrench. TIS says 21 Nm for the former and 19 Nm for the latter. I did the two nuts above the transmission mounts and the bottom nut/bolts on the passenger side by feel.
Would the additional rigidity of the setup have any potentially long-term adverse effect on the engine or drivetrain? Only thing I'm concerned about at this point is whether it might exacerbate the engine mount issue, as there is now less isolation between the components.
      09-07-2010, 11:57 PM   #35
fatmatt0116
Hooligan
fatmatt0116's Avatar
Drives: 2014 Porsche Cayenne Turbo S
has anyone heard anything about the quality of the rogue transmission mounts? I have a set sitting in my living room and am debating whether or not to install it....
2011 X5 5.0 Dinan - SOLD
2007 Imola Red Z4 M Coupe -SOLD
2004 Navy Blue BMW 325Ci
      09-08-2010, 02:53 PM   #36
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Mine went in 4 hours ago. Appears to be less cabin noise then with the OE's. Won't know the performance until Friday.
2006 Z4MC - #LL93158
      09-08-2010, 03:30 PM   #37
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
That's because the RE's are filled with silly puddy.
      09-08-2010, 03:46 PM   #38
RBull
^lol
      09-08-2010, 05:42 PM   #39
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
      01-22-2011, 07:26 PM   #40
a_riddler
Bimmer Noob
a_riddler's Avatar
Drives: 08 Z4MC;08 MBZ E350 4Matic
Just finished up mine, went with the red set, no enforcer cups.
Made the mistake of torquing down to 20lb-ft and not 16 (torque wrench only went to 20 and figured it wouldn't be that big a difference). Wow, what a racket that made! Put it back up on the jack stands, torqued it to 16 (with new torque wrench, yeah!) and purrs like a tiger now at high RPMs.
I used a 1/4" ratchet and two fingers to tighten the top nuts, save yourself the hassle and pick up a flex-head ratchet. The space is very tight.
Thanks again for the write-up!
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing,
AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges
      01-22-2011, 08:13 PM   #41
Shipkiller
Shipkiller's Avatar
Drives: Me
Now for the dumb question:
My Zed is a daily driver and I saw 10 track days this year. Does 10 track days constitute heavy track use?
I am on fence between the option 1 (blacks, with or without cups) or option 2's (reds).
Thoughts from people who have them installed?????
I am on travel now and won't be home until Feb 5th, so if I order soon, they should be waiting for me...
Too damn much snow up here in CT..
      01-22-2011, 08:15 PM   #42
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Just go with the RE's
      01-22-2011, 08:18 PM   #43
Shipkiller
Shipkiller's Avatar
Drives: Me
Caddy,
Talked to the wife yesterday. She went out in the garage and then said that my car looked sad... She said my car misses me and needs to be driven.....
      01-22-2011, 09:09 PM   #44
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Option 1 w/o caps or RE's
