      10-26-2009, 01:18 PM   #1
usurp
Kuwait
Drives: 2005 BMW Z4 Roadster - 3.0i
Help with technical stuff like backspacing and offset
Hey guys, my OEM z4 wheel cracked and another is dented so i decided to order some new wheels from tirerack. Now I put in all the details 2005, BMW, Z4 3.0 and its displaying a bunch of wheels for me. I am stick to 18" but every wheel i click seems to have a different offset and backspacing. What do they mean?
I found for example some BBS RX with the following specs:
Offset: 38mm Backspacing: 6.0" Bolt Pattern: 5-120
I then checked the BBS CK and it had the following specs:
Offset: 45mm Backspacing: 6.29" Bolt Pattern: 5-120
What does it mean?
thanks!
2005 BMW Z4 Roadster - 3.0l, SMG, M Seats, Eisenmann exhaust and Hardtop.
      10-26-2009, 02:15 PM   #2
nickpapa
nickpapa's Avatar
23
Drives: Z4 3.0
backspacing is the distance from the inside face (the part pressing against the rotor) to the inside edge of the rim.
so for the example above, the RX will stick out more than the CK (if they are the same size and width)
      10-27-2009, 11:19 AM   #3
usurp
Kuwait
Ah cool thanks. so whats the OEM backspacing or offset?
      10-28-2009, 12:57 PM   #4
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
Which OEM wheels do you have?
You can find the offset on RealOEM.com
Click here
      10-28-2009, 01:00 PM   #5
usurp
Kuwait
I have these
http://www.realoem.com/bmw/showparts...43&hg=36&fg=15
02 TWO-PIECE LIGHT ALLOY RIM 8JX18 ET:47
02 TWO-PIECE LIGHT ALLOY RIM 81/2JX18 ET:50
      10-28-2009, 01:02 PM   #6
usurp
Kuwait
damn, my OEM's cost over $800.. thats crazy
