      07-31-2009, 06:20 PM   #1
fitchesbass
Drives: BMW
Z4M offsets
Will I need to or should run any spacers with wheels of offset et 30 in the front and et 37 in the rear?
They are wheels off an E90.
Thanks!
      07-31-2009, 06:45 PM   #2
apexstrafer
Drives: Z4 M Coupe
The et 30 up front will already be pretty flush (possibly too aggressive), depending on the width of the wheel. Et 37 on the rear will likely need spacers, again depending on wheel width.
      07-31-2009, 08:11 PM   #3
fitchesbass
Drives: BMW
awesome thanks for the quick input
      08-01-2009, 12:25 AM   #4
wyu177
Drives: 2019 m240i
I had to run a 10mm H&R spacer on my rear 37 offset rim. 30 offset for the fronts seem to be ok...
      09-19-2009, 09:04 PM   #5
AWM3
BMW Fan
AWM3's Avatar
11
Drives: 2012 E92 M3, Alpine White
I have E92 wheels on my Z4M, however their offsets are 34 front and 37 rear. I am using a 15 mm spacer on the back for a net offset of 22 on the back. No spacer was needed on the front.
