08-14-2007, 03:19 PM | #1 |
Rep 80
this won't fit my Z4...or will it?
08-14-2007, 03:29 PM | #2 |
M = Midlife Crisis
65
Rep 2,006
I subscribe to the you get what you pay for set - I would not risk it.
2006 Z4MC - #LL93158
08-14-2007, 03:32 PM | #3 |
Rep 80
I can't find anything on them, although they are a well known make and all.
08-14-2007, 03:39 PM | #4 |
Rep 1,210
It will "fit" but with very extensive custom fabrication which will cost a lot of money. The thing with turbo/sc kits is that if you buy a kit not made specifically for your car you will have to do a lot of welding and fabrication for all the piping, mounting the intercooler and making sure all the fittings work. My friend is working on a turbo kit on his Acura Type-S he opted to buy individual pieces and fabricate his own piping and mounts and he is already 2 months past his original finish date. Your best bet is to wait for a kit specifically designed for our cars. If you have a pre-06/07 z4 there are already supercharger options out for your car.
08-14-2007, 03:52 PM | #5 |
Black Opps field agent
35
Rep 449
Drives: 135i M
could be a fun project. if you don't need to use your Z4 for a month
:rocks: Montreal to Vermont OktoberFast cruise. :rocks: http://www.e90post.com/forums/showthread.php?t=79557 |
08-14-2007, 08:13 PM | #7 |
My favorite sign.
169
Rep 4,333
I dunno...it doesn't look like much to me.
08-15-2007, 04:05 PM | #9 |
Rep 1,689
The supercharger is probably of questionable quality, and using a block off plate with a silicon hose adapter to connect to your intake manifold sounds like a flimsy bad idea. That supercharger is hardly light enough to be supported by a silicon hose. If the belt moves, you're in trouble. The supercharger needs to maintain a set distance from the motor and the belt needs to be of the proper size. That just looks way too ghetto to be putting on any car you value. If you want to have fun with it, I say try mounting it on your lawn mower.
I'd steer clear of that ebay supercharger. At least ebay turbos are less work. Although the turbo may split in half due to the glue they used to hold the compressor and the exhaust turbine together. |
08-15-2007, 06:47 PM | #10 |
My favorite sign.
169
Rep 4,333
S/C lawn mower...now that souds like a fun weekend project.
