      08-03-2007, 03:58 PM   #1
h7y
Drives: 3.0i 6 speed with stuff on it.
Rotors Question
Hey guys would my stock Z4 rotors go on a 3 series? I have them from the 3.0 sports package. Thanks for the help
      08-08-2007, 10:41 AM   #2
pbdm4k
pbdm4k's Avatar
Drives: 2010 335d
measure the diameter of the two, if its the same it should fit.
      08-08-2007, 10:47 AM   #3
ward
Drives: F
I highly doubt it'd work, the bolt holes for the wheels will match up
but the thickness of the rotor, offset distance from the hub, diameter of the rotor......
      08-08-2007, 10:52 AM   #4
pbdm4k
pbdm4k's Avatar
Drives: 2010 335d
I'm sure it would work just fine if the rotors are the same diameter and as long as they're both vented or unvented, it should fit.
Hell, I don't see why you can't swap the calipers over too if the two bolts that hold it in are in the same position as well.
