08-29-2015, 12:23 AM | #1 |
1621
Rep 4,294
Vanos elimination kit, Achilles
Hi guys, anyone know anything about this kit?
Sooner or later my vanos will need a core exchange, and was wondering how this does the same job as the vanos?
Powered by |
08-29-2015, 09:48 AM | #2 |
Rep 164
Drives: 08 Z4M Coupe
Vanos elimination kits would be useful if you are planning to run LONG duration cams (like 304/296), and don't care about loss of low end torque.
It makes sense in race applications, as you are trying to ultimately build as reliable a motor as you can (thus eliminating possible points of failure like VANOS) while maximizing high RPM power. for a street driven car it doesn't make too much sense given the drawbacks. |
12-10-2015, 10:31 AM | #5 |
10841
Rep 4,891
It also requires stand alone ecu. (but when racing one's probably using that already)
04-15-2016, 03:31 PM | #6 |
Rep 688
you will start hearing noise from the front almost like a timing chain rub sound....it will only get worse
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor |
04-15-2016, 04:29 PM | #7 | |
Rep 2,287
I would not do it, cheaper to fix the vanos. |
